Question about Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television
Need help troubleshooting sudden "no signal" error
Setup: TH-50PHD7UY with DVI card (TY42TM6D). Plasma is fed signal only through DVI cable. Cable is connected to an Anchor Bay iScan HD scaler/processor. I have a DVD player and a TiVO (HD) connected to the scaler. Problem: Have had this setup, working since December 2004. Now, for the past month, the video signal suddenly cuts out with the message "no signal" displayed. This happens either with a DVD or Tivo program being displayed, Which seems to rule out either of these devices. The signal drop times vary - sometimes the display will last 2+ hours, othertimes it will only last 20 minutes. I've taken to powering down the monitor to see if this is related to its reaching full operating temperature. It does not seem to matter. It does not seem to be overheating. If I power the monitor off, and then back on, I get the picture back, but typically only for a few minutes. If I power cycle the scaler, the image on the monitor does not restore. This seems to point to either the plasma monitor itself (ugh!) or the DVI card - I am hoping it is the latter since I want to upgrade to HDMI (provided a card is even offered for this model). I've jiggled cables, etc to rule out a bad connection. I have not tried bypassing the DVI card yet and going component in, simply because of the huge hassle it will be. But I suspect I will need to next. Any sage advice out there, diagnostic technique, similar experiences? Thanks! Tony
  • GeneP Dec 21, 2007
    Tony,
    I have begun having the same problem. I have 2 of the DVI boards installed and they both act the same way. After some testing, I did see that when the DVI signals cutout after a couple of hours, the component signal is completely unaffected.
    I have also run the component signal straight through ~28 hours with no drop at all, which to me suggests it is not an overheating problem.
    I did call and log a case and twice had a local shop engaged but they have been pretty useless in getting to root cause and fixing it.
    Did your issue get resolved? if so, can you let me know the outcome, parts replaced, etc?
    Problem Solver:
  • 8 Answers
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Posted on Mar 25, 2008
SOURCE:
I have @ panasonic plasma display model TH=50PHD7UY serial YH5120189 and my question is how can I connect cable tv in to because does not have the connector on back?
Hello
Your TV has no direct cable connector. You can connect it to cable via converter using SERIAL (D-Sub 9pin [RC 232] type connector wire from converter to your TV. It is designed so. High Density D-Sub 15 pin connector is used to connect this Tv with computer. OK.
Jul 21, 2011 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
Iam trying to connect hp laptop to my th-50phd7uy i need driver software.thanks
Consider using "PowerStrip" which can give you custom resolution modes. It costs about $30 but has a 30-day trial period.
Jan 02, 2010 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Unexpected zoomed-in picture on my JVC PD 42X776
Depending on the cable provider there is a zoom function on the cable box remote , # for time warner.
Feb 27, 2008 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Game console and plasma displays
You did not list which console you have and what type of cables it has.
Looks like your plasma has:
1 component
1 composite
1 VGA
1 S-Video
If this is an xbox360 or PS3 then you will want to use the component connection, but this one is already used by the cable tuner. Don't worry there is a solution. The xbox360 and ps3 output a higher resolution that your plasma can handle, so use the component with those systems.
If it is an older console, predating the xbox360, then use the composite or S-video connections.
Since you are short on video inputs, you might need a video switch. A switch with both component and S-video connections for future add-ons.
You can find them all over the web, or your local video store like walmart and best buy. Here is a switch i found on ebay that should work:
http://tinyurl.com/3aoev9
here is the ebay search i used:
http://tinyurl.com/2ograc
Make sure you buy extra cables, most of these boxes do not come with cables, so buy what you need.
I prefer video switches that don't require a power outlet, but it's your choice. Some of the powered switches, have remotes for the lazy people, but I don't need anymore remotes on my table, keep that in mind.
Feb 14, 2008 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Check Signal Cable
there maybe something called source on th screen somewere push that button
Nov 19, 2007 | HP Compaq FP 7317 17" Flat Panel LCD...
TV screen turns off, green light stays on
As posted for a similar problem:
T Wiz
Aug 31, 2007 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television Logo
298 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
