Question about Toshiba "52Z3500 52"" Multi System LCD TV"
I need a replacement remote for a Toshiba 52Z3500T 52 inch LCD TV. The remote number is CT 90291
  • 3 Answers
SOURCE: programing my toshiba remote
go here:
http://www.tacp.toshiba.com/televisions/lcd/large.asp
select your tv and then click on resources and then open up the manual for your tv.
Posted on Dec 31, 2008
  • 60 Answers
SOURCE: Code for Magnavox Univ remote
Try one of these codes:
018, 021, 023, 071, 085, 090
If those don't work, respond with the model for the remote and we'll try some others. Also, if remote requires 4 digit codes, just put a 0 in front of each of the above.
Posted on Apr 06, 2009
antone_avata
  • 16 Answers
SOURCE: our 42 inch Toshiba LCD TV, model 42Z3030DB has a
yes! at the it's own center!!!!!!!!!!!!! ^_^ ok? ha?
Posted on Oct 18, 2009
  • 4 Answers
SOURCE: my brand new 52 inch toshiba lcd tv screen turns
I bought a 52" 1080p 52VR series for $100 dollars off of craigs, Half the screen would flicker at bright colors and then bam, solid lines on exactly half the screen. About three hours later I have a new regza running like a charm. The issue is and I quote "Toshiba, Samsung, Vizo are all ****, they don't have fans and burn out or they have surges from outlets". Removing the back and pointing the fan the modules it delayed the amount of time before flicker occured and was able to pin point which board it was by unpluggin one by one from connection, (psu was working fine) until I came to the T-com board covered by foil on top. I've done wonders with my heat gun (Props to Microsoft and HP as your shortcuts deflected excuses, horrible offshore service, and short warranties made me small fortune on xbox's and dv9000's alone.) ((to Schanoop at microsoft, keep laughing your kids college fund was spent on sweatpants for the homeless)), my 1257 revived and resold laptops and 360's and now 3 flat's all from my "19.95" husky heat gun. Back to the point.
The corners cut today are fans and leaded solder that won't crack or melt. hairlines cause catastrophic problems. I removed the T-con panel (you tube this before you try it and watch it done first) placed chip and pin side up on a marble surface using four 1/4 bolts placed under each fastner slot. yet agian you tube red ring fix with heat gun, but in circular motions heat the points of contact on the board (where chips and connectors meet SF objects, and for about 2 and half minutes heat the cheap solder up to let it reform. Gravity itself will take care of the rest as with the chip facing up (connectors as well) it will sink back fixing any cracks or broken connections. Most improtant, don't touch it, let it fix itself by giving it 45 minute minimum cool down. and thats how I got a 3 thousand dollar TV for one hundred dollars.
Just incase you have the same problem and this didn't fix it, these are the other things I did with the board off. Remove the foil from t-con shield, (i tossed it) and where the ribbons meet the lcd itself, I noticed the distribution boards have small pegs to sit in for fit and restriction. However I'm guessing do to poor ventalation, these boards were warped and refused to stay flat and would pop up and off the pegs. Using tweezers I held them on the pegs and used a buffing wheel off my dremel as a pad to put pressure between the metal frame and the board so it was forced to stay flat and on the peg. second thing I did was handle my t-con (aside from the points it's a tough little board) like an unwanted cat as fell off the tv onto hardwood, I used a 48 watt solder to touch the tips up and accidently solder a SFC to an open circut, couldn't even see the damn switch without a 10x loop, I used a desolder gun to fix the intermitten issue. I am positive however that the problem lied in the solder they use to save costs as it melts at low heat, and when your pushing technology thats running twice as hot because the numbers are bigger make for unique opps for my heat gun. I'll work on a shorter version but after reinstalling, I threw a cpu fan above the t-con and it's been smooth sailing.
Posted on Jun 20, 2010
SOURCE: Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Posted on Jul 12, 2010
Need code to set up Ellies slimline remote on Toshiba 20VL66A LCD TV - Toshiba remote CT-8006 no longer working
0028,0091,0086,0025 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Televison & Video
My tv flickers 37inch
Steven, based on your model number...you have a 52 inch tv, correct?
TeeVeeMan2@gmail.com
Sep 16, 2011 | Toshiba 52HL167 52 in. LCD HDTV
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
Can you send me a manual of this tv as i bought it today - but it has not a manual, toshiba ct - 90307 thank you in advance Anne
CT-90307 is your remote model number.
There isn't separate manual for the remote, but you can download the manual for the 42WLG66 (free) from here:
http://tesc.toshiba.co.uk/Web/ModelLis.nsf/1f82d70b57a6d36d80256a000042a0fb/1600b70b21cbf8188025718d00490dc9/$FILE/32WLG66P%20Euro%20OM.pdf
Once you have opened the file you can print it or save it.
Please rate my solution if you find this helpful. thanks.
Oct 15, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Crack front panel LCD 52 inch TV
My fiance threw my remote at my 52 inch Sony Bravia lcd and I am lost on what to do, How much will it cost to replace the lcd and i dont want to pay to much.help me
Aug 04, 2008 | Televison & Video
Toshiba "52Z3500 52"" Multi System LCD TV" Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
