Question about Belling XOU492 Electric Double Oven
My Belling XOU70FP Light in main oven won't work, even with a new bulb
SOURCE: just brought belling xou594 double
BELLING XOU252 WHEN IT IS SWITCHED ON IT TRIPS THE MAINS ALL WIRES SEEM TO BE GOING TO EARTH.
THANKS
MEL
Posted on Aug 16, 2008
  • 44 Answers
SOURCE: belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
Posted on Mar 19, 2009
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: fan oven option not functioning on main oven
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Posted on Oct 24, 2009
  • 4 Answers
SOURCE: Belling XOU 252 Oven suddenly stopped working
need new element that is element code "AB20" from link below you need to remove 2 screw or nuts that holds back plate element is behind it then pull oven out remove back cover remove element wires and put every thing reverse order
element code is AB20 link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
Posted on Dec 24, 2012
Belling XOU70FP tripping the mains supply, any suggestions ?
Strange that it does not blow a fuse. Is it tripping the main switch or an earth leakage switch? There is obviously a short circuit and you need to call an electrician. It could be an element, but lacking more specific detail I would be guessing.
Sep 06, 2010 | Ovens
My Belling oven isn't working at all- no power or
Be careful with one. Turn power off at the mains first then change the socket. I suspect the wires were loose in the socket and heated up and damaged the switch. If you have a continuity meter try checking between live in and out and neutral in and out on the socket
Oct 24, 2009 | Ovens
Do i need to use a housing unit with the Belling XOU70FP Double Built under electric oven
Not if you you don't want to, it can be used freestanding if you so require.
Thanks.
Aug 06, 2009 | Ovens
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Belling no heat in main oven
You need a new element buy on line much cheaper,
Jul 23, 2008 | Belling XOU592 / XOU593 Electric Double...
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Mar 13, 2007 | Belling XOU492 Electric Double Oven
Belling XOU492 Electric Double Oven Logo
22 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
