Question about Kenmore 98702 Stacked Washer/Dryer
Dryer Problem The timer on the dryer does not work. The dryer still works fine, but the timer does not allow for automatic shutoff or regular heat cycles
    Scholar:
  • 146 Answers
Replace the timer.
Posted on Nov 04, 2007
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
The timer on my dryer isn't working properly
HI. the timer motor is damaged at this point. The Auto sector is dead. This is not a serviceable part, and you will need to replace the entire timer mechanism to correct this issue.
Oct 02, 2009 | Frigidaire Dryers
No heat when timer is in Electronic Sensor selections.
The electronic sensor needs to be replaced.
Sep 16, 2009 | Dryers
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
