Question about Watches
Change the time on bench bc0385wh - Watches
How do I set the time and date on my bench digital watch
hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Nov 26, 2015 | Watches
Bench bc0051 time set instuctions
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
May 21, 2013 | Watches
I'm unable to reset the time on my Bench Watch, the serial number on the back is BC0013BR HL Hope you can help me out on this
press and hold the LIGHT button - it starts the settings. MODE changes between time date etc START
Aug 06, 2010 | Watches
How to set time on Bench Gents LCD Strap Watch
How to set the time on a bench digital watch Bench BC0013BR
Oct 26, 2009 | Watches
Reset time on bench watch bc0013br
I have a Bench Watch BC0013BR and do not know how to set it up any help would be appreciated
Oct 05, 2009 | Watches
How do i adjust the time on this watch
how do I get off military time on this armitron instalite watch
Mar 22, 2009 | Watches
The user guide is wrong
I have a Theorema Parago Automatic through not wearing it regularly it sometimes stops. Winding it wouldn't solve the problem and I couldn't find a solution either on the Theorema site or online so through a series of self help efforts the following is the solution for this watch 1 Set the watch to the correct time date day etc. 2 Wind the watch using the side winder for about 40 revolutions in clockwise rotation 3 Hold the watch in your right and strike it firmly into the stiff palm of your left hand. This gives the winding mechanism a shark shock and kicks it back into life.The watch then works away without a problem.
Nov 17, 2008 | Ebel Tarawa Automatic 9127J40/5435136...
Setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Oct 16, 2008 | Watches
Bench Watch BC0088 set up manual
Hold down the bottom left button for 5 seconds. It goes to set mode.
Apr 26, 2008 | Watches
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Watches Logo
32 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
