Question about Kodak EasyShare M1033 Digital Camera
I have a kodak M1033 camara. In the book it shows a battery level icon at the bottom of my window on the back of my camara. Mine does not show that icon. How can I make that show? Thank you
  • lpljnanke Apr 23, 2009
    It says one view one solution but there is nothing to read that you have solved the problem.
Well wha you can do is
Posted on Apr 23, 2009
Screen and view finder not showing anything
Just covering the bases...
Make sure the lens cap is removed
Turn the ON/OFF switch to Favorite mode
Press EVF/LCD does it toggle
Look to see if the battery level ICON shows better then half
Battery combination sometimes will show a strong icon level
It may be strong in the other modes which draws less power then the picture taking mode.
My guess would be New Battery replacement.
Some tests were done that may be of value to your solution
http://reviews.cnet.com/digital-cameras/kodak-easyshare-z740/4505-6501_7-31294317.html
Jun 13, 2010 | Kodak EasyShare Z740 Digital Camera
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
I can not transfer my pictures from the M1033 easy share kodak to my computer. Please help!! I am connecting the usb cable to the camera and computer and turning the camera on - nothing happens! When I go...
I typically recommend using a card reader- it's a constant and generally works better and it keep the wear and tear down on the camera/battery. I'd recommend you try using a reader and see if it's working correctly. If not, look at the USB port and also check the hardware (Device) manager and ensure that the USB ports are working properly.
Jul 08, 2009 | Kodak EasyShare M1033 Digital Camera
I have a Kodak M1033 camera that I bought just over 6 months ago. I took it on holiday it worked fine and then suddenly it switched off. Since then it only powers up for about 5 seconds, shows a unfoc
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 02, 2009 | Kodak EasyShare M1033 - black Digital...
Battery will not stay charged after being fully charged
How old is the battery?
These happen when battery becomes weak/faulty.
If the battery is new, ask for replacement.
If old, time to get new.
Thanks
May 30, 2009 | Kodak EasyShare M1033 Digital Camera
Battery showing low charge but i have charged it fully.
Uses 1 Li-Ion (3.7V, 1050mAh) KLIC-7004 ensure this is your battery type and didnt see anything on it but they have a live chat on kodak website.good luck
May 03, 2009 | Kodak EasyShare M1033 Digital Camera
Battery level icon does not appear on camera screen
Just chatted with Kodak, {in Manila} the Tech said the icon will appear when the battery is low.He said you should still be able to take about 15 more pictures once it appears.We'll see I guess.Good luck.
Apr 27, 2009 | Kodak EasyShare M1033 Digital Camera
Display battery level
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
Mar 17, 2009 | Kodak EasyShare M1033 Digital Camera
How do i view the battery indicator on the Kodak md1063 digital camera. Handbook shows icon bottom right, however this does not appera. I did notice the icon when I first switched on - battery required...
I'm not 100% sure about this. But I "think" the battery icon is a warning icon that only shows if the battery is depleted by more than 50%. That's certainly how it works on other Kodak cameras.
Aug 05, 2008 | Kodak Cameras
Kodak EasyShare M1033 Digital Camera Logo
236 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
