Question about Maytag Neptune MAH6700A Front Load Washer
How do I remove the softener dispenser in a speed queen machine
3 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Automatic fabric softener dispenser does not dispense anymore.
replace the control board
Posted on May 26, 2008
SOURCE: SOFTENER DISPENSER DOES NOT WORK
Here's an easy, but likely, thing to check. If your machine seems to fill more slowly than it used to, it could be a partial blockage at the supply valves - enough to hamper flow to the dispenser. Turn off the water supply, remove the hoses, and check the in-line hose filters. Worked for me.
Posted on Apr 11, 2009
Frigidare top loading washing machine, 1995 model # GLMS174SAS4
I believe the softener is dispensed through centrifugal force when the machine is in the high speed spin after draining and before filling for the rinse cycle. I had the same issue on another machine. Use very hot water and a washcloth to clean out the softener cup. When adding softener at the beginning of the load, only add the recommended amount and then fill the remainder of the cup with water.
Mar 06, 2015 | Washing Machines
How do i remove fabric softener dispenser
To remove the fabric softener dispenser, pull up on the dispenser to remove it from the agitator. Grasp both ends of the dispenser and squeeze it in when you are pulling it up.
Feb 10, 2012 | Washing Machines
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Jul 25, 2011 | Speed Queen AWS44NW Top Load Washer
How do i take the softener dispenser out to clean
Pull the drawer out there should be a small plastic tab located in the back corner. Depress this tab and pull the drawer out.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Speed Queen AWS44NW Top Load Washer
Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Sep 28, 2009 | Washing Machines
Softener getting all over top rim of washer
i tell people to dilute it with water so it is not as thick.
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Maytag Neptune MAH6700A Front Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
