Question about Hoover H3045 Vacuum
Hoover freejet lost power - Hoover H3045 Vacuum
Where can I get a mother board for a Freejet 3in1 cordless hoover model FJ180WB2
probably need too replace the whole board. safest way in case board is at fault. Appliancepartspro.com with model no.
May 02, 2016 | Hoover Vacuums
Hoover freejet agitator not spinning
belt is either broke or put on wrong,Check the belt :)
Feb 15, 2015 | Hoover Freejet Fj120wb2 3-In-1...
No power
there should be a fuse next to the power supply. If fuse is good, than the power supply is faulty.
Sep 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover vacuum model - U6317-930 lost power. I
Something is definitely loose in that area. Replacing the related parts is probably the best fix.
Jul 17, 2009 | Vacuums
Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Freejet Cyclonic will not charge after battery run flat
basically, the batterie pack is shot and it will cost about £40.00 ish to replace. as you said, a right rip off
Dec 24, 2008 | Vacuums
The PCB controlling the battery charger is overheating and the led dosen't illuminate when charging, could the led be shorted internally causing the problem. The vacuum in question is a Hoover Freejet...
The problem was caused by the failure of 7 of the 1.2volt cells in the battery pack, the other problems were symptoms of the battery pack failure. Replaced the thermal cutout a 131 degree C component on the PCB in the docking station for the vacuum when recharging, I also had to change the LED which had also failed this is a Red 12 volt 5 mm dia component observe the correct polarity when replacing. Also make sure when replacing the thermal cutout that it is secured tightly to the resistor it sits along side, otherwise it will not respond quick enough if there is another failure.
Jun 22, 2008 | Vacuums
Hoover Vacuums - F5914-900
No reset, could have a bad cord, switch or motor. Just has to be checked to find the problem.
Mar 04, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover H3045 Vacuum Logo
21 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
