Question about Dishwashers
Washer off. water builds up in the bottom of the
Washer off. water builds up in the bottom of the dishwasher and overflows onto the floor when door is opened
  • hansendl Apr 23, 2009
    Thanks for the info on my leaking dish washer,it did help.
    Hansen
  • 234 Answers
It sounds like your water inlet valve is defective. The part is under $50.00 usually and is fairly easy to replace. It is located under your machine where the water hooks up. It has an electrical plug attached to it. It is usually blue with a metal bracket attached to it.
If you need more help, post another question with the model and serial number of your machine so we know exactly what unit you have.
Good Luck!
Tim
Posted on Apr 23, 2009
Dish washer spills suds on floor
Sounds like door seal. The rubber seal ends at the bottom of both sides. examine the ends to see if they look the same. some have a plastic insert. it may fallen out. cheap part to order.
Apr 14, 2014 | Whirlpool Gold WDT910SAYE Fully Integrated...
Water level too high overflowing the tray and comes out bottom of door
Drain the dishwasher. There's a box in towards the front of the door. It's shaped like an oval. Carefully remove and clean that. Lift it up and down after and listen for clicking. Try running it again.
Mar 14, 2012 | Dishwashers
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
Model DU8700-xb purchased 1995 When unit reaches
Please check your overflow float. It may be stuck in the down position. It looks like a little hat or cone in the bottom of the machine. It should move freely up and down. If it is stuck in the down position, your machine may over fill with water and cause your leak. Good luck
Jan 23, 2010 | Dishwashers
After two to three days the water starts to appear
hello mam
please check the solenoid walve which controls the water to check this please open the top cover of the washer and see the water line where the water hose pipe is connected there you can find the solenoid walve and observe this as you give the supply and timer switch is ON you hear the sound of the walve operation while it opens the line to take the water and as switch of the mains it should shut the water line to stop the intake of water and if this operation is not happen then please change the solenoid walve.
Oct 07, 2009 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Leaks badly
Most dish washers do not seal at the bottom, the door lip just sits
in front of the tub lip and does not make a real tight seal like a refrigerator door, so unless water is spraying out the top and sides of the door,I would assume that it is either overflowing,or you are using the wrong detergent and it is just foaming to much inside the washer and going over the lip and dripping on the floor. Once the suds stop getting agitated then turn back to water and don't look like suds.
So if you watch the washer during the cycle and the water s only coming from the bottom it is the water level switch inside on right
in the front,looks like a mushroom, once the washer reaches a certain level of water this switch floats up and shuts off the water to stop it from filling anymore. If this seems to be the case just remove the front bottom kick panel and you should be able to see the switch, watch it when the washer is filling,you can also push up on the little arm and the water should shut off. Post back with any questions.
Apr 16, 2009 | LG LDF6810ST Stainless Steel Built-in...
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher overflowed out of d/w during wash cycle; not draining
2 things to check
First turn off the power(breaker box to dishwasher and sdisposal
open the doors to your sink and and check the hose for any kinks etc
open the dishwasher door, bail out water remove the spinning hub and see if you can remove
the strainer and bail out more water
you can use a baster to **** out more to view
to see if the pump area is plugged
reverse proedure and turn on dw
listen to see if the pump engages on that cycle
hopefully this solves problem
If the pump does not engage you wil need to call for service
Jan 01, 2009 | Mx Commercial Line Drano Max Clog Remover
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
