Question about Microwave Ovens
Kaiser cuckoo clock kw 701 electronic circuit
Kaiser cuckoo clock kw 701 electronic circuit driving clock mechanism and cuckoo, will not open or close doors exposing cuckoo, pendulum stops, dancing figures will not rotate yet music plays
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
  • 6771 Answers
SOURCE: The turntable starts rotating as soon as the door
It sounds like you have defective door switch, and it should be checked for safety issues.
Posted on Jan 28, 2011
The Clock on my old, large Quasar Microwave does not work. How can I turn it on?
On some ovens, the clock would go blank when you opened the door. The same thing would happen if one of the door switches failed, or was not activated by the latch mechanism. I'd check that first. Otherwise, it could be a failure of the electronics in the control panel, or something else.
Apr 17, 2016 | Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
GE Profile JE2160 - Just stopped working. Touch pad works, light goes on when door opens. When starting, timer counts down, can hear a relay click, but nothing (no fan, no turntable, no magnetron. Fuse...
Hi
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. You should check the internal door switches, the high voltage circuitry and the circuit board for this kind of problems. But for that you will need a certified technician to help you make these repairs.
Aug 19, 2011 | GE JE2160 Microwave Oven
Have a Panasonic Microwave NN-SA616W, when door is closed looks like touch pad works perfect, but when I open the door start to make a clicking sound and the light starts to function intermittently (like...
There are usually three interlock switches in the door mechanism. One is in the power circuit for the magnetron, one is in the relay drive circuit, and the third is a logic input to the controller. Many times the one in the relay drive circuit turns on the oven lamp when you open the door at the same time it disconnects the magnetron relay. If the lamp relay is stuttering irregularly, that door switch may be going bad.
Another possibility (if this happens only when you open the door while the oven is running) is that the magnetron power door switch is stuck in the on position. This is not a safe condition. Replace that door switch ASAP, and get in the habit of turning off the oven before opening the door.
May 31, 2011 | Panasonic Microwave Ovens
Model KHMS155RSS microwave is not heating food after the maid service cleaned the microwave
Hello, does microwave have power? Plugged in etc, lights working on front? All microwaves have a safety backup, the door may press onto a latch which will allow the microwave to work, this is to ensure that if you open the door during cooking, it will stop immediately so you're not exposed to microwave radiation. Maid may have disrupted the mechanism for this purpose, make sure door latches are OK, and door closes smoothly, also try unplugging and then plug it in and turn it back on. Hope this may help..
May 22, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
