Question about Daewoo Washing Machines
DAEWOO WASHING MACHINE DWD-L1221 DOOR WILL NOT OPEN
Master_Tech
  • 770 Answers
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Posted on Aug 02, 2008
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
SOURCE: Daewoo washer - LE error message
replace the lock switch
Posted on Dec 27, 2009
SOURCE: Daewoo wash machine air power 7kg Model DWD-F1013.
i bought used but good working daewoo f1013 washing machine in dubai,
i can not spin. no drying. i dont have user instruction manual.
please help
Posted on Feb 11, 2011
  • 6277 Answers
SOURCE: i have a daewoo 7kg
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
Troubleshooting
Best bet would be to unplug the machine, leave it for 30 seconds, then try plugging it back in.
Oct 19, 2013 | Daewoo DWD M1031
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
How to change the switch door lock
What is the model number of your unit?
Nov 02, 2012 | Daewoo DWD M1031
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
69 people viewed this question
Top Daewoo Washing Machines Experts
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
