Question about LG Refrigerators
The latch on my LG refrigerator model lfc20760sw door has dropped down and so the door will not latch properly. How do i fix it?
5 Suggested Answers
  • 58 Answers
SOURCE: Refrigerator door has dropped 1/2 inch
that happens too all sxs ref. sometime there is an adjustment on the bottom hinge
Posted on Oct 31, 2007
  • 52 Answers
SOURCE: My LG refrigerator is model LFC25760SW, double
I'd look into the original owners manual that shows how to align the French doors when first purchased. Sounds like heavy usage, or it was improperly put on when you first got it. Try that first, re-align, and tighten the bolts. Last resort is replacing the latches, call the LG customer service center at 1 800 243-0000 for details.
Posted on Feb 06, 2010
  • 4793 Answers
SOURCE: The refrigerator door seems to have dropped about 1/8 inch.
it is possible that the floor under the adjusting bolt has dropped,place a carpet protector cup under all the feet and then, using a level, make sure the unit sits square,the door may need some adjustment after this but you will see, that is a simple task.
Posted on Mar 31, 2010
imufo2
  • 3773 Answers
SOURCE: I have the LFC20760SW.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 16, 2011
My refrigerator lg LFC20760SW. It just went off by itself. It won't power on at all what can I do.
Check to see if breaker is tripped .Unplugged fridge and check to see if there is power to outlet .If there is power to the outlet then follow the fridge power cord and check that connection .Maybe a burnt wire
Jun 03, 2017 | LG Refrigerators
I have an LG model LFX25974ST refrigerator. My issue is the ice flapper that allows the ice to drop will not open.partment and clog up. if i hold the flapper door open manually the ice drops down and
http://c.searspartsdirect.com/lis_png/PLDM/F1107036-00005.png
405A
on diagram Motor,dcPART NUMBER: EAU59551201 $27.41
Back ordered Call Marcone appliance ... Or goto searsparts
but this is the part you need.... To access it take outer door appart
see diagram on searsparts.com
Jan 16, 2014 | LG LFX25960ST Stainless Steel French Door...
Ice through trap door
To prevent this problem of ice formation, you need to maintain a fix time interval of switching on and off your refrigerator unit. It will help in maintaining cooling as well as ice level.
Jan 02, 2014 | LG LFX25960ST Stainless Steel French Door...
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Replace door latch on lg refrigerator
Put the LG in the trash. I did after pay 150.00 three time to fix the latches that kept breaking. LG stands for Loads of Garbage.
May 12, 2012 | LG LFC23760SW Side by Side Bottom Freezer...
I now have the same problem: I HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT COVER INSIDE THE FRIDGE MELTED DUE TO THE LIGHTS STAYING ON WHEN THE DOORS CLOSE. THERE ARE BUTTONS ON THE INSIDE UPPER DOOR...
LG has issued a service bulletin about this problem. You need to call LG or the ratailer you bought it from and tell them what's going on...the entire cost of the repair (parts and labor) should be covered....at least it was the last time I did one for a customer.
Oct 04, 2010 | LG 22 Cu. Ft. French Door Refrigerator,...
My LG refrigerator is model LFC25760SW, double door, bottom freezer. When you close one door the other door opens slightly. I think the top latch has weakened. How can I repair this? Are new latches...
Feb 05, 2010 | Refrigerators
I am looking for a refigerator either side by side with no water and ice or a bottom freezer refridgerator needs to be 31 inches wide.
Have you checked out the LG model LFC20760SW French door with no external dispenser, which fits a 30 inch wide opening? (PS. Buy from a small dealer, not a big box or Sears if you want good service over the life of your product) Check where to buy at with your zip code http://www.lge.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC20760ST.jsp but avoid the big guys. You may have to go to a 10 or 20 mile radius to find a servicing dealer, but it will be worth the effort.
Jan 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
What does dE flashing on the LG intellowasher WD1050FHB mean?
It is an indication of door error. The door is either not shutting, locking or opening.
  1. Turn off the unit and unplug it for 5 minutes then replug and turn it on. If the problem persists, proceed below.
  2. Check the door latch
  3. Check if there is something that is caught in the door and prevent it to shut properly.Remove any stuck items that might push the door latch up or down during operation.
  4. Check if the door or gasket is damaged. Damaged door or gasket will prevent the door from latching or locking properly. Replace damaged gasket. Dis-aligned door prevents the door latch to lock properly.
  5. Check the door latch for any damage. Replace if defective.
Nov 04, 2009 | LG Washing Machines
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
