My DAB radio wont tune in to a station, just displays ''tuning''
The display only shows ''tuning'' flashing on and off. i have had this radio for a while and it has always worked great, but something happened to make it stop working. i cant use the tuning buttons, it doesnt respond and there is no sound playing at, even white noise. It is a CMT-spz90db model can someone tell me how to tune into the stations again?
  • sanjaylb May 24, 2009
    i have the same tuning problem with a sony micro hifi cmt eh20dab. Just displays tuning without actually doing any tuning!
This is not a solution but a suggestion - My Dad has this Hi-Fi and also has the same problem, unfortunately his warranty ran out 6 months ago. So, because of this I opened the stereo up. Inside there is a little (4in by 3in approx) PCB at the bottom back of the Hi-Fi above the CD section. This PCB is the tuner board. On this board there is another board (hybrid) with a BGA (Ball Grid Array) chip. BGA's sometimes lose connections between the pads on the board and the contacts under and on the chip. I am away in Germany for a little while but in 3 weeks when I visit my Mum & Dad again I am going to take the tuner board out and take it to work where we have a special heat gun for lifting surface mount chips. I am going to flux and reheat the BGA chip to reflow the joints under the chip. I am a Senior Test Technician with PCB experience so I DO know what I am doing. I let you all know how it goes.
Posted on Jan 31, 2010
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Radio appears not to work at all. No sound.
check to see if you have 12 volts at the memory (yellow in most cases) wire it should be powered all the time the red wire is acc. key on
Jan 17, 2014 | Yamaha MCR-042 Micro Component System...
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
I recently moved my Legato Pure radio, now I have trouble tuning in the DAB radio and the display struggles to set the clock often flashing with a message saying it is wating for time to set. When it does...
Clearly, the DAB signal strength is poorer in the new radio position. Try moving it, even a foot or two can make a difference. Better still, use a roof aerial.
The display can be changed, even in standby mode - press the Display button to see the 3 options.
Dec 19, 2009 | Audio Players & Recorders
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Nov 10, 2008 | Audio Players & Recorders
DAB RADIO MATSUI MATCR 515D- ILLUMINATED TIME/STATION DISAPPEARED - NO RECEPTION - MUSH CAN BE HEARD IN SPEAKER
It is possible for the display to be set so low that it is not illuminated at all. With the radio off (i.e. the set must be in standby), press and hold TUNE+ to raise the brightness level.
If this gets the display back, you may be able to see what has happened to the tuning. e.g. check whether the tuner is set to FM or DAB etc.
Apr 29, 2008 | Audio Players & Recorders
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
1,707 people viewed this question
 Grubhead
Grubhead
