Ritetemp 8022c How can I override the system's programming? We just moved in and I don't want to program it, just override it for now.
  • 148 Answers
Set your temp and press HOLD button
Posted on Nov 10, 2013
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
No you can not , overwrite in same microcontroller
Posted on Oct 15, 2013
Only rings 3 times then transfers to another ext.
Mitel call forwarding is a double-edged sword. It can be controlled by the end user via user-programmed forwarding and it can also be controlled by the system programmer via system call rerouting. User programmed forwarding OVERRIDES system programmed 1st alternate, but does not override the 2nd alternate reroute destination (if 1 is programmed). Try un-forwarding the phone - if still no joy then contact the system support person. Hope this helps. (User-programming commands are initially defined by the system support people when the system is initially installed, so I can't tell you how to do it... you'll need to know what the key commands are (or unforward using the Superkey function if provided).
Dec 13, 2013 | Mitel Lands Phones
Ritetemp 8022c
After you program the thermostat..the temperature numbers stays on the screen a few seconds then starts to indicate the temperature of the room. This is normal.
Nov 29, 2013 | Heating & Cooling
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 24, 2012 | Hardware & Accessories
I hope I am stating my problem clearly: I just purchased a Woods 59377 indoor timer that I'm about ready to return to the place I purchased it because of the manual override button. What I didn't...
I have 59377 timer in my office.
Here is copy of manual:
http://waterheatertimer.org/pdf/Woods-59377.pdf
What job do want the timer to do?
It sounds like you want a programmable timer at night, and simple on-off switch at day.
Add a comment if answer below misses the mark.
YES, the manual override can be used as on-off switch.
Press manual override until Manual ON or Manual OFF display.
The manual override button has 4 states:
Auto ON, turns lamp ON immediately and programming resumes at next set time.
Auto OFF, turns lamp OFF immediately and programming resumes at next set time.
Manual ON to choose permanent ON.
Manual OFF to choose permanently OFF.
Aug 26, 2011 | Woods 7 Day Digital Heavy Duty Timer...
My thermostat is not working properly.I took off the plate, and connected the rh wire to the w wire, there is a spark, but heat still will not come on. should these wires both be connected to the rh...
The rh and w wires should not be on the same screw. That would make the heat run all the time because it would bypass the thermostat. It sounds like you had power on the rh wire which is the hot wire from the transformer. If you connected it to w and the heat still didn't come on then your problem isn't the thermostat. You should check the contactor or relay that makes the heat kick on. I don't know what type of system your thermostat is controlling so I can only give you limited advice on that.
Nov 14, 2010 | Heating & Cooling
Pool will sporatically alternate between spa and pool mode. The JVA valves will at like they are confused and move back and forth even though the pool was completely off
You need to check and see how many different programs you have set in the control. If you change a program or add one the old one stays and will cycle and override any others that are in the system. You probally need to remove any old programs in the system. The valves running after the system is off is probally the system reseting. You would probally do best to clear the whole system and start new. Good luck.
Feb 26, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Programing a new remote
Use these instuctions if your Deville has an Analog Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Panel (CCP) simultaneously.
(Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode.
Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP.
If “RFA DATA” is displayed, press FAN DOWN.
If “RFA OVERRIDE” is displayed, press FAN UP.
2. If “RFA 500 NO OVERRIDE” is displayed, press FAN DOWN.
If “RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP.
3. IPC will show “0” on right side of Driver Information Center (DIC) display.
Press warmer button on climate control unit until “99” is displayed.
4. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not
programmed within 30 seconds after entering “99” override display, system will default and you must begin again at
step 2.
5. To program a second remote, press FAN DOWN button until “RFA 502 PROGRAM FOB #2” is displayed, then press
FAN UP. Repeat step 4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will
light all telltales, go blank then enter DIAGNOSTIC
MODE. Press FAN DOW button to scroll through system until
“RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then
press FAN UP button. When “NO OVRD RF 500” is displayed, then press FAN UP button.
2. When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just
below odometer. System is now ready to program remote.
3. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
step 2.)
4. To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to
program second remote.
To exit system, press RECIRC or RESET buttons.
Disclaimer
Apr 25, 2009 | 1998 Cadillac DeVille
Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Jun 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
312 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
