Question about Coffee Makers & Espresso Machines
Approx. 3years old. never removed from box. box and instructions w/plastic bags destroyed. need manual and list of plastic bags
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Coffee Maker... Master
  • 102,366 Answers
What make and model coffeemaker?
Posted on Oct 12, 2013
Ignition switch need removing
if this is your first car? do wiggle the steering to unlock the dogs
and 100x that if parked down or up hill , wheels to curb. RTM
read the operators guide , its covered.
lost the guide? in the glove box have you? bingo.
http://justgivemethedamnmanual.com/honda/
read the pages on key , and locks.
are you asking how to REMOVE IT? the Verb missing,???
this is covered in the FSM. buy one, lots of steps it is...
alldata.com covers this.... read it, and defeat the AIR BAGS first. !!!!
here are some free FSM , honda;s are great that way.
http://hondatech.info/downloads/Auto/Manuals/Accord/
on most cars. , "GENERIC RESPONSE"
battery neg lug, removed and safed off (warp in towel> so it cant land on post accidentally) .
I recommend, always to READ THE MANUAL. the FSM.
the factory service manual.. (it's for real mech, not DIY but is best)
RTM, read the FSM on air bag defeats, some can retain a charge for hours. or more... RTM it's your neck not getting snapped.
1; BATTERY PULL NEG LUG.
2: DEFEAT AIR BAGS.
3:remove steering wheel, (rtm) (a whole section just that)
4: do not damage the Air bag coil spring(above) or be real angry when it fails
and not pass smog test , gigs yah.......oops. or cant sell car?/ oops......
5: remove the plastics, there. (wrap) (bottom screws)
6: remove column , switch clamp , most cars show a set of anti-tamper screws here, (RTM) we must destroy them to take them off , and replace them later.
7: cables removed from switch.
8: the whole switch assembly is free, key on. (not locked)
9: out it comes. off end of column.
the key switch is protected with antitamper features.
read about them, then attach the switch.
Dec 26, 2013 | 1996 Honda Accord
Replace ignition switch
what year, what country? Usa, Canada. where?
how do I replace and ignition, switch?
post symptoms and country for best help.
the procedure , is same ,most cars this era.
its in the FSM and on line at Alldata dot com and mitchels.
1: Defeat air bags (they can kill or maim any mech)
2: pull battery minus lug, not plus.
3: remove plastics surrounding the combo lever area. (bottom screws)
4: remove tamper screws from lock switch clamp. (grinder)
5: remove lock, some require steering wheel removal.
if you remove the wheel, most DIY will destroy the main spring for
air bags, a very costly mistake, again, RTM (read the manual) read the FSM, read the factory service manual. or fail.
6:
unplug the switch cable.
slide switch off steering shaft.
, reverse above, for replacement.
(the air bag spring ,needs careful attention)
working on modern cars book free, is a fail, situation.
the cost to read an FSM is 4 bucks a day.
not 100.
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
look , capture screens, print the applicable screens and get to work.
May 28, 2013 | Suzuki Grand Vitara Cars & Trucks
Hi we have a 4 person Heritage Spa and request an operation manual please.
What is it you want to know? The manuals usually do not provide any info that you can't learn in one use of the hot tub. You can't break anything by turning knobs or pushing buttons.
If you want to know how to program your spa, then that is different. Please provide the make, & model of your specific spa control system. This info is found on a label on the metallic or plastic load box that house the spa's circuitry. If there is a s/n and or a code number that will assist as well.
Dec 18, 2012 | Pool & Spa
Take out ignition switch
there are 3 sections in the FSM covering this topic, short and sweet
remove lock cylinder, (lock smith) steps.
remove only the switch section.
remove the whole thing.
which one is you.?
the last one requires the steering wheel removal.
got air bags, that is step on in each case.
1:battery neg lug removed.
2: defeat air bags per FSM steps, can kill a mech, they can.
3, remove the plastics, surrounding the column comb, and switch.
then.....
its all at alldata dot com, all steps and to not get HIT by the BAG.
or how not to destroy the AIR bag clock spring in the steering column $$$$)
Nov 23, 2012 | 1995 Geo Prizm
Hi, How can I replace the power cable of a kirby ? Thanks gs
You'll need three types of screwdrivers. A straight edge, and 2 Torx, sizes 15 and 20.
With the vacuum in an upright position, remove cord from holder. Use the #15 Torx to remove the two screws holding th cord to the vacuum. Use the #20 Torx to remove the screw where the cord enters the vacuum. Insert the flathead screwdriver into the slot on the left side of the "box" and release the tab. Gently pull on box at the top and tilt out. Unplug the old cord and plug in the new.
Reverse these instructions to put everthing back together.
Here's a video showing how it's done on the Sentria. It's the same on my G4, so should be the same for a G6. Excellent video with easy to follow instructions.
http://www.youtube.com/watch?v=rXZjv3mh280&playnext=1&list=PLAD4F1D2DB5A5C97A&index=11
Jan 06, 2011 | Kirby G6 Bagged Upright Vacuum
Hi, I found on a street market a MIYOTA T241 watch in original package, also a plastic shield on the glass. Now the problem: May be the liquid of the battery destroyed any power supply wires or contacts. I...
mcdevito75 here, Once the battery leaks it destroys the quartz mechanism. Even if you find a replacement quartz, you"d need special Jewelers tools to remove and replace the quartz, even with that you could destroy the new quartz if you can find one. Best Bet, see a small watch repair shop in your area for a quartz replacement approx. $75.00
Sep 29, 2010 | Watches
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a old bbq but the plate is rusty and old fat or oil has dried on it how can i get it like new again
Hi, there are several products you can buy to clean this to almost like new again. I know it will take some elbow grease also.Get something that removes rust 1st, and a cleaner of industrial Strenth and concentrated . You can get these cleaners at a janitorial supply store and they will show you what to use also. Best of luck, Shastalaker7
Nov 24, 2009 | Grilling
Bt 70r instruction manuel needed need manual or details how to pair bluetooth in car device
BT70R pairing with a new phone
The code for pairing with a new device is 0000.
However, the BT70R retains the identity of the phone that is is paired with and this old code must be removed before a new phone can be paired. There is probably something in the manual for this, but I have lost my copy. Here's how I got round the problem...
Place the BT70R in a sealed plastic bag (to protect it from moisture) and then put it into your freezer and leave for 24 hours. When you take the BT70R out it should have lost its memory of your old phone and you can pair it with the new one.
It worked for me!
Oct 21, 2009 | Car Audio & Video
Need repairs
This is the list of the dealers i could find.Please do rate my solution if accepted.
CREATIVE SEWING CENTERS 747 BOONE AVE NORTH
GOLDEN VALLEY, MN 55427 763-513-9822 Approx. distance: 5 mi
PARK VACUUM CENTERS INC 7008 HWY 7
SAINT LOUIS PARK, MN 55426 952-922-2824 Approx. distance: 6 mi
CHANHASSEN VACUUM PO BOX 206
CHANHASSEN, MN 55317
Approx. distance: 10 mi
CHANHASSEN VACUUM 80 WEST 78TH STREET SUITE 130
Hope the information was helpful.All the best.
Apr 10, 2009 | Royal 4000 Classic Bagged Upright Vacuum
Coffee Makers & Espresso Machines Logo
22 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
