Question about Craftsman Garden
Ignition coil wiring diagram
Do you have a diagram to change the coil on a Craftman mower 917.289283
  • Sharon Autey
    Sharon Autey Oct 13, 2013
    Need to replace the coil. Have a new coil, but no diagram showing where it is located. Need to know what I have to do to replace it.
  • Craftsman Master
  • 2,478 Answers
Go to you tube On line write repair coil craftsman mower.
Posted on Oct 14, 2013
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
mowerman1857
  • 389 Answers
SOURCE: need to see a diagram of how to install a craftman
Go to Sears Parts on line, it will show an exploded view of the belt in the configuration that is required
Posted on Sep 14, 2009
daneinwv
  • 124 Answers
SOURCE: I need the belts diagram
My name is Dane, and I
Posted on Dec 05, 2010
aquaman987
  • 927 Answers
SOURCE: mower will not start, seems
Remember, if all of the safety interlocks aren't "made", the ignition circuit will never "close".
The symptom will be not even trying to turn over.
Gary
Posted on Jun 28, 2011
  • 6468 Answers
SOURCE: need wiring diagram for snapper mower model 260612t without electric star
don't have a diagram but i find the safety switch relay goes bad just disconnect it go right from the key switch to the engine just to test it of course also check the switch on the shifter handle
Posted on Apr 24, 2012
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
Why does my craftman riding mower withut off when i engage the mower lever i have replaced the seat switch and the interlock switch
did you replace it (the seat switch) with the correct one for your model?
I ran into this one time
Nov 04, 2015 | Garden
I need a wiring diagram, mainly from ignition switch to coil/stator.
pull the black ground wire off from the coil,try to start the motor,if it starts,put the wire back to shut it off,,,one or all of your safety switches is bad,you can bypass all the safety switches(as long as you dont care),by putting a switch connected to the coil and the other side,a ground,if you want safety switches then you have 3 to choose from to replace,2 stop the mower from starting and the 3rd stops it from running if it did start,here is a 42 inch,pretty much the same,you didnt tell me what model or make, http://www.ereplacementparts.com/craftsman-917279841-riding-mower-parts-c-158286_174089_460323.html
May 05, 2015 | Garden
My Lawn mower is not starting even after changing and replacing a new spark plug?
First use a known good plug; new doesn't mean good all the time.
You need to check for spark by seeing if the plug or plug wire will arc to ground. When doing make sure insulate to yourself from it as there a 10-15 kv charge on that wire / plug if the coil is working and you will receive a nasty shock.
If no arc then check the ignition coil by removing the kill (stop) wire from the coil and try for again as above. If still no arc then the ignition coil is bad. If you now receive an arc after removing the kill (stop) wire then have either a bad kill (stop) switch or a short in the wiring.
If you replace the ignition coil the air is .010 -.012 normally on most small engines.
Dec 17, 2014 | Garden
Why my 6.5 craftman eager-1 has no spark
Check the engine stop wire where it connects to the carb mounting plate. make sure it is not shorted to ground. Remove the top cover from the engine and check the flywheel to magneto air gap, it should be about .020 of an inch, this is about the thickness of a matchbook cover. Also check the spark plug wire and the connections, make sure they are clean and tight. The magneto is the y shaped piece behind the flywheel. Remove the flywheel holdown nut and washer and make sure the notch in the flywheel and in the crankshaft are across from each other. If they are not, you will need to remove the flywheel, and replace the aluminum key that goes there. The notches need to be aligned for the ignition timing to be correct. I hope this helps, good luck. Dan
May 23, 2014 | Briggs & Stratton Briggs Stratton...
Question on craftman riding mower
with the ground wire off the coil and it turns over, you have a bad coil these engines are notorious for this. GOOD LUCK.....
May 23, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
Need diagram for 22.5 craftman rideing mower
go to sears parts derect .com and inter your model # you will get all the parts diagrams
Jun 07, 2012 | Craftsman Garden
Coil on Brigg straton lawn mower does not produce spark
If there is no spark and the wires are ok, face the fact that the ignition unit requires replacement, any amount of testing it is not goig to get you anywhere
Feb 12, 2012 | Garden
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
Aug 27, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
53 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
