Question about Sony Playstation 3 (PS3) Console
About 2 weeks ago the fan in my ps3 starting making a horrible noise and froze my system up. would not turn off or anything. since then it does it sporatically, sometimes after a couple hours or just half an hour. dosent freeze up but still slows it down and wont turn off. suggestions?
    New Friend:
  • 156 Answers
I would guess you have alot of dust in your console might be aworth opening it up and using a can of compressed air to blow all the dust out.... also some of those fans are ball bearing and it may be going bad and not pushing enough air anymore that would cause the system to over heat and cause your problem too
Posted on Oct 14, 2013
4 Suggested Answers
  • 27 Answers
SOURCE: problem with ps3 system restore
Connect via the USB cable and press the PS button this will re pair the bluetooth,
Posted on Jun 11, 2008
  • 41 Answers
SOURCE: My ps3 is stuck on the system update screen on
Your PS3 hard drive may be corrupted. Do you know, send back to game shop is too expensive and waste your time. Learn the repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only hard drive problem, you can repair other red and yellow light issues as well. After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Posted on Jul 20, 2010
  • 225 Answers
SOURCE: ps3 only goes to start up screen no further
The actual freezing problem can be caused by the GPU overheating and SO can the no display error as well. For an in depth look at how to fix both of these problems see this > http://www.bestps3repairguides.com/
Posted on Mar 13, 2012
PS3 fan keeps making noise
If it's an older system, break that thing open and clean it! ^^ If it a newer system, or you just don't feel like stripping it to clean it, then use an air compressor to blow the crud built up in the back of the system. Make sure the compressor hose is dry, as you don't want water to get inside your system. Good luck, and I hope this helps.
Jan 21, 2014 | Sony Playstation 3 (PS3) Console
Sometimes when starting 2000 lincoln signature tc the idle will surge as this awful sound like someone blowing a conch shell ?other times w /do same while driving. Only way to stop noise is to push qu
the compressor that pumps up the air suspension does make a horrid noise, and if you can turn it off, like I could in my crown vic, just long enough to see if that is indeed the compressor making the noise you hear, then try that. My switch was located in the trunk.
Mar 21, 2013 | Cars & Trucks
My desktop computer will display anything when turned on, and the fan and hardrive both make a loud constant noise.
Maybe you need a larger power supply depending on if you might have added more hardware such as a graphics card, or an extra monitor to your system. This sometimes results in an inefficient supply of power, making your fan to your power supply work harder, thus making noise.
Nov 19, 2012 | Gateway Computers & Internet
Compressor problem
is the sub is distorting then the "compressor" or voice coil will make horrible noises. Turning down the settings on the amp that is powering the sub will help decrees the noise.
Aug 20, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Just replaced trans 2 weeks ago. Now, i go out to my car, and its making a horrible noise, like the fan was stuck on something. 2 different ppl told me it was the motor? You agree or should I check...
best advice here is ask a local mechanic who will be able to tell you exactly what it is without even lifting the bonnet ,i would tell you exactly what the noise is if i could hear it ,as this noise could be anything from a clutch bearing if a manual or a flex drive plate if a auto but without knowing the full info of the vehicle i honestly cannot say
Mar 18, 2011 | 1995 Isuzu Trooper
PS3 WHEN CONSOLE SWITCHED ON IT BEEPS THEN TURNS OFF AND FLASHES RED
My guess is its going to die soon. I would back up most of your stuff on a hard drive if possible. If it gets that far. I had this happen to my 40GB PS3 about a year ago. It turned on for 5 minutes then off. Soon after that it didn't turn on. And it was making really loud fan noises.
What are the specs of your PS3 and was it making loud fan noises before? Consider buying a new PS3 slim?
A quick guess that i just thought is try doing the fan test before turning it on. Turn Off PS3 completely (switch in back) Hold eject button and Turn on switch.
NOTE: This is dangerous and can harm the PS3.
Good Luck
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Fan blades will not move when first turned on then when finally get going fan makes horrible rattling noise
Either the bearing on the motor has gone bad or maybe a little spray of w40 may solve the problem. Provided the fan blade is not touching anything.
Jun 26, 2010 | Dryers
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
1st 80Gb ps3 model gets hot really fast..
Make sure that your not placing your system on any sort of carpet or rug this will cause the system to overheat. Also check the fan on the back of the system and make sure that the fan is clean and not full of dust and other sorts of stuff. If this does not stop then i would go buy a cooling fan for it just to make sure it dont fry the motherboard!!
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not recognize discs of any type when inserted.
Call sony or take your ps3 apart and clean the lens
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
