Question about American DJ Dyno-Fog-II Fog Machine W/ Remote System
Shoots out liquid instead of fog...
I have an American DJ Dyno- Fog 2, instead of shooting out Fog, it shoot out liquid. I've been told to let it heat up first but I did that and their was no difference. If anyone can help, please do, I really need this work as soon as possible. Thank You!
    Problem Solver:
  • 4 Answers
That thing(the heater) just doesn't work well,
bring it to someone to repair it
Posted on Apr 23, 2009
My fog storm 1700 turns on but the machine will not heat up
Replace the circuit breaker by opening up the machine. You do this by unscrewing all the screws and exposing the circuit board. You will then be able to detach the 2 cables going to the circuit breaker and unscrew the circuit breaker's thread on the outside thus releasing the circuit breaker. Hope it helps!
DJ EM-A
jmavila02.wix.com/djem-a
Nov 18, 2011 | American DJ Fogstorm 1700hd Fog Machine W/...
My Fog machine will heat up, and say it's ready, but when i press the button, it makes a buzzing noise and no fog will come out.
This is kind of late but I have one here now and the same thing...only difference with mine is that the green ready light will not come on either. I managed to get mine to output fog. I had to remove the hose form the pump inlet and bleed it to get the air out of it. It is like syphoning liquid from one container to another so to speak....fill the container with liquid, fill up the hose with liquid so that there is no are trapped in the hose, attach the hose to the pump and then submerge the other end into the tank. Turn on the unit and let it heat up. it should work ok..unless you have a problem with the pump itself..
Jan 18, 2011 | American DJ Fog Storm 1200HD Fog Machine...
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
The problem i have is the mechine turns on the liquid heats up i get a lil bit of warm up smoke and when i press the button no smoke doesnt even sound like a fan is push anythin it does even make a noise...
Hi dj4mbit
to answer your question;
I`ve repaired quite a few foggers and very often the problem is with the remote control and/or its cable+connector.
Otherwise your problem might the pump for the liquid that has seized up(common problem) .
Jan 19, 2010 | American DJ Fogstorm 1700hd Fog Machine W/...
Shoots liquid not fog
you need to let it fully heat up first!
Nov 15, 2009 | Fountainhead/Burgess Prod Black Flag...
American DJ Vaporizer Fog hog
Sounds like the pump either is not working or can't inject the fog fluid ( solution of distilled water & glycerin ). My unit clogged up, so I took it apart and cleaned out the lines. Be sure to run pure distilled water through unit, after each use.
Oct 30, 2007 | American DJ Fogstorm 1700hd Fog Machine W/...
Low fog output
I had the same problem with an American DJ, I removed the pump took it apart and cleaned it. It had a stuck valve in it. It now works fine.
Oct 27, 2007 | American DJ Dyno-Fog-II Fog Machine W/...
American DJ Dyno-Fog-II Fog Machine W/ Remote System Logo
379 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
