Question about Microwave Ovens
The oven on my 22 y/o Whirlpool RM286PXV 2 micro-wall oven runs 50 or more degrees lower than the setting. Both elements work. Will replacing the control module behind the temp control knob solve the problem?
SOURCE: Panasonic NN 9850 wall micro/convection oven
PLEASE CHANGE MEMBRANE SWITCH
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: thermador microwave from oven/micro/warming drawer
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Posted on Aug 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1874F Low Convection Temp
We have the 2 service manuals you need to refer to for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The manuals have a safety info, disassembly info, troubleshooting chart, test procedures, part numbers, etc.
I would first suspect a bad thermistor, but it should be checked, as well as the line voltage at the outlet, etc.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Jan 09, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Convection Preheat doesn't reach the Chosen Oven Temperature
I would first suspect the thermister (thermistor) or a low line voltage, weak control board relay etc.
But the service manuals will show you how to safely disassemble, test and repair the unit.
We have the service manuals for this model and have uploaded them to our site here and here to help you.
You will need the
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
MicrowaveSvc
  • 9047 Answers
SOURCE: PLMV169DCD Frigidaire Microwave Over the Range Oven Quit
We have the service / repair manuals for these models and have uploaded them to our site to help you.
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
I would first suspect the C/T fuse or the oven thermal cutout.
Accessing some components for testing will require you to remove the oven from the wall.
The manual covers this as well.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Please write back if you need further help.
Posted on Jan 26, 2009
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
I have just moved into a 10 year old house. It has Blanco gas cook top and a Blanco wall oven. My problem is the electric starter for the gas top does not work. and the Oven indicators eg. top element,...
#1 You may have a blown fuse which sets all these issues together
#2 Your sparker may need to be tested, try a voltmeter to it and see what it reads. If voltmeter reads voltage, then it's a simple adjustment of distance to contact. If no voltage, then you'll need to replace sparker.
#3 as far as your indicators, that has to be an internal fuse.
I agree with you for not replacing these appliances, I love to cook with gas
Dec 16, 2010 | Microwave Ovens
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
My micro wave will not warm items up
You have not given much information, but it appears the Magnetron element (the heating device) in your oven has failed. Repairs are not cost effective my friend. New units are low priced and have many new features. Consider this.
Nov 13, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
