Question about Craftsman Garden
Sears Super Start Front Tine Rototiller won't start. No instruction manual for how to start it. Got it at garage sale last year. Started perfectly for the owner. He had to adjust a couple of screws so wouldn't be rich in gas. Took it home and put in storage building. Took it out today and can't get it to start. Is very old and the choke, fast and slow are wore off so can't tell what drive it is in.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Choke may be causing flooding of the carburator.
Change the Choke.
Posted on Aug 01, 2017
  • 246 Answers
SOURCE: I need a parts list for gilson rototiller 1573A
Hello johnoliverpe:
Have you Tried this Site Addy;
http://rustytiller.com/manual.html ?
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
#1 Taper
  • 1040 Answers
SOURCE: rototiller won't start
There are a number of thing that it could be, so lets start from the beginning. Check these off the list as we go:
1. Does it have fresh gas?
2. Check to see if the fuel line(s) are in good condition; (no cracks/breaks).
3. Make sure the fuel filter is not clogged.
4. Do you still have the original carburetor guts in it?
5. Make sure that the carb. is good and clean. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean all the small portals/jet. (Use carb. cleaner)
If you have any other questions, just let me know.
Jim
Posted on Jun 10, 2009
  • 202 Answers
SOURCE: Replace belts on Montgomery Ward rear tine
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Posted on Oct 25, 2009
  • 221 Answers
SOURCE: have a rototiller it moves ok but the tines do not
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Posted on May 06, 2010
SOURCE: sears rear tine rototiller 32-29978 manual
I have a sears rear tine rototiller 7 horse 17" and the left side tines do not turn but the right side does
Posted on Apr 10, 2011
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
We have a rototiller, craftsman, bought new at sears several years ago. Model No. 944627591, Craftsman 9 HP, 21 inch tine width, rear tine tiller with counter rotting tines. Pinion input gear is sheared...
The model ID starting in 944 indicates your tiller was manufactured by Husqvarna. This division has since been purchased by AYP. A quick online search finds that www.needlawnmowerparts.com lists having one for $55 plus shipping. I have not dealt with this company, so I can't recommend or not recommend them.
It is very common for tiller makers to not offer internal transmission parts. Transmissions are difficult at best to repair and reassemble. Used tillers are available from time to time, check your local classified ads or www.craigslist.com to find one. If you decide to go with a new tiller, i would recommend trying www.northerntools.com or www.mytsc.com to start your search.
As far as longevity on the new transmission, Sears won't guarantee any of their parts longer than 1 year. However, you should expect a replacement part to last as long as the first one did.
Sears doesn't give year models for their equipment, but usually supports replacement parts for at least 10 years. Most equipment manufacturers don't build their units to last longer than 10 years....they want you to buy another one.
I hopethis has helped.
Jan 04, 2011 | Garden
Yard Machines rototiller front tine- having problems starting
Sounds like you are either losing your "prime" or your carb needs either, cleaning, rebuilding with a kit. Probably a cleaning will do it. Watch U Tube there are wonderful people who film the whole process from tear down, to replacement. Com'on! Get into it its easy and it don't take long. Then you'll always know how to do it!
May 04, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Rototiller pull start won't pull
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
Jul 28, 2009 | Husqvarna PRRT850X 960920015 CA 17" Rear...
Jim
Jun 08, 2009 | Husqvarna PRRT850X 960920015 CA 17" Rear...
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Garden Logo
4,315 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
