Canon MP360 - "Data Error Press Set Key" Message
SOURCE: error 345 on canon mp360
look here:
http://www.techimo.com/forum/showthread.php?p=2219482#post2219482
Posted on Oct 15, 2008
  • 421 Answers
SOURCE: Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Posted on Nov 11, 2008
  • 22 Answers
SOURCE: Canon MP390 - "Data Error Press Set Key" Message
No free suggestions go to the authorised service centre or trying to get an live chat support from canon like I do from my hp printers
Posted on Mar 05, 2009
michael_grey
  • 365 Answers
SOURCE: Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Posted on Jun 17, 2009
SOURCE: Need help to solve this
i'm facing the same problem....pls help...tq
Posted on Jan 31, 2011
CANON MP360 ERROR MESSAGE WASTE INK NEAR FULL CAN IT BE REPAIRED
Locate the sponge taht soaks up the ink wash it in water and washing up liquid
strain it out till dry...ish
then
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Mar 20, 2011 | Canon SmartBase MP360 All-In-One InkJet...
Message appear 'paper jam'
Have another look, especially the front rollers, all it takes is a small piece of paper in the right place, to get the error message. How do I know, cause it happened to me today.
Nov 07, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
A message saying waste tank nearly full comes up and i need directions to fix it?
Hello. this message indicates that the computer merely has to be reset [canon is hoping you will take your printer to them for a costly tuneup] here are the steps to reset your counter:
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Here is a link where you can download the entire service manual for $4.00. http://www.tradebit.com/filedetail.php/4546475-canon-smartbase-mp360-mp370-mp-360-370
Oct 13, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Printer says cartridge is jammed press the "set" but I can't find any such key
This is just an educated guess however "set" is the term used by Cannon to refer to the operation of installing a new ink tank, possible they are requesting you remove and reinstall the ink tank, ensure it is in the right slot and ensure you hear a click.
http://www.retrevo.com/r/262bh333/85/Replacing+An+Ink+Tank#q=Canon+MP360
Sep 10, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Canon MP36 error ##343
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Hope this helps!
Rehards,
HP
Aug 28, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Feb 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon smartbase mp360
Try this:
Reset Waste Ink counter:
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Kindly rate as Fixya if you found this helpful. Thanks.
Oct 26, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Error code printer check ** 343
the error is "Waste Ink Tank Full" error
This error occurs after a set number of nozzle activations, and it's to protect you from having ink start leaking out of your printer.
The waste ink tank is actually a large cotton pad in the bottom of the machine which absorbs the waste ink, and if this pad becomes full, the ink will pool and, like water, seek the path of least resistance, which could be where the case parts connect, and then leaking out onto your desk or carpet...
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
hope it works for your model
Hope it helps.
goodluck pls dont forget to rate this
Sep 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon Multipass MP360 - Paper won't feed
Your Manual will tell you what this error means
or look in
www.fixyourownprinter.com and type the printer model in the field
Nov 03, 2007 | Canon MultiPASS MP360 All-In-One InkJet...
530 people viewed this question
k24674
jasbo
jasbo
