Question about Milwaukee Tool Milwaukee 18V 1/2 In Hammer Drill Kit 0627 24
5380-21 Milwaukee 1/2" hammer drill stopped running. Was plugged into a converter off the truck with a heavy duty extension cord. I was drilling into concrete with ease and made it through 3 holes. The drill is young with light use. I did take it apart to look for scoring or burns and looked brand new. Do you think the trigger fried? Also did try in several outlets without an extension cord with no luck. What do you think?
  • 2976 Answers
SOURCE: My 0624-20 18 volt 1/2
Run the drill at about 1/2 speed for an hour to seat the brushes. This will clean the armature and prevent arcing from the new brushes.
Posted on Aug 08, 2009
  • 10865 Answers
SOURCE: I have a cordless 14.4 Milwaukee Driver/Drill that
You can have this rebuilt at any milwaukee service center for about 50 bucks, half the price of a new one.
Posted on Oct 01, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a parts manual for a milwaukee 5316-21
go to Milwaukeetools.com and under service/parts type in your model number and you can download a manual and parts breakdown. Let me know if you need more assistance.
Posted on Feb 12, 2010
rowdy45176
  • 2176 Answers
SOURCE: when one "Burns out" a
it is, however sometimes the cost is the limiting factor. If you give me the model number and brand I can try and find some prices for you. But some of the major tool manufacturers offer a MAX RATE repair that sets the limit on how much it will cost you and they will fix everything. If it is less then you pay less.
Posted on Apr 16, 2011
rowdy45176
  • 2176 Answers
SOURCE: i want to repair cable on a milwaukee hammer drill 5392-1
If you mean the cord you can find the part number by going to milwaukeetool.com and you will need the serial number for the correct one. Or you can also go to ereplacementparts.com. You will need to solder the wire ends to push into the swiitch. To release the old cord straighten one leg of a paper clip and insert next to the wire and gently pull out the old cord. UNPLUG tool first and make note of where the wires came from. The Milwaukee site also has a wiring diagram that you can download. Let me know if you need more assistance.
Posted on Mar 17, 2012
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
How to fix my heavy duty 120v drill
Sounds to me your armature needs replacing. Basically brushes either work or don't work. some times you may get heavy sparking but that is the spring not pushing the brush on to the commutator. Loss of power and smoking usually armature if you use the drill in this state you may burn out the field coils as well.
Jul 05, 2014 | Milwaukee Drills
The drill will hammer but won't turn you can hold it with your hand even on level 6
you didnt specify what brand or model so I will take a shot at this, does the tool have a high/low selector and if so is it fully engaged in one position or the other?? if not get back to me with the brand and model and I will do some research for you.
Oct 02, 2010 | Milwaukee 3/4" Rotary Hammer Drill Heavy...
Put drill in revcerse and the chuck comes loose dropping the bit out
Yup, that is what happens. You can lessen that by really cranking it down, but it is an issue with most hand tightened chucks, and does not indicate a mechanical failure. I sometimes miss my old, heavy Milwaukee wrist-breaker with the keyed chuck. If it is just too much to live with, you could get a drill with the click in hex chuck or put a Jacobs keyed chuck on your hammer drill.
Anyway, I hear where you are coming from and share your frustration.
Regards, Farmerbear
Sep 09, 2010 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Milwaukee heavy duty hammer drill only works when pointed upwards. As soon as I point it down the motor stops (or doesn't start with the drill in that position).
could be loose connection at the switch or brush holders. You can go to Milwaukeetools.com to download a breakdown for this tool.
Aug 14, 2010 | Milwaukee Drills
I have a really old Milwaukee 3/4" rotary hammer, I don't know how to get the bit out, any help would be greatly appreciated
if it does'nt have a keye'd chuck, it may have arubber collar,spary some lube down into chuck and firmly push down,w handle agains't ground or other firm surface
Apr 20, 2010 | Milwaukee 3/4" Rotary Hammer Drill Heavy...
I have two dewalt 1/2 electric drills and the extension cords are cracked. how can i replace the extension cords?
You will need to lay the drill on a bench then remove all the screws that hold the two halves of the case together, carefully pull the case apart to expose the wire connections
Mar 07, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a Milwaukee 1 1/8'' heavy duty hammer drill, and it is fairly new, and I can't get any bits to lock in place. The coller that the bit fits through doesn't slide back and forth. What can I do to get...
Milwaukee has a 5 yr warranty on all their tools. Best thing to do is find a service center in your area and have them look at it. Sounds like the bit collar is stuck or possibly cracked. No sense in spending money on the tool if you can get it covered under warranty.
Jan 25, 2010 | Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Milwaukee Tool Milwaukee 18V 1/2 In Hammer Drill Kit 0627 24 Logo
64 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
andrew-loeb
Level 1 Expert
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
