Question about Maytag PAV2300 Top Load Washer
Does not spin
Our Maytag Performa Washer Model # PAV2300AWW will fill, agitate wash, drain but will not spin.
  • 7 more comments
  • tlopez Feb 23, 2008
    I think there is something, maybe a rock or bobby pin, stuck in the washer somewhere. What do I need to do?
  • Anonymous Feb 29, 2008
    my washer fills,agitates,drains,but wont spin.
  • Markj2008 Apr 28, 2008
    I have the same problem, very noisy but will not spin. Is it the belt? What is the problem?
  • Anonymous May 09, 2008
    will not spin. pumps the water out but will not spin the clothes
  • tucsonjim Jun 14, 2008
    It started making screeching noise when going in to spin mode. Sounded like metal on metal. When the cycle was shut off and turned on again, the sound started again. On one attempt, it would not spin at all and hummed as if the motor was overcome with resistance. Upon inspection, I find the motor shaft turns freely without any indication of worn bearings, the pump pulley turns fine, too. The tub also seems to turn fine without any evidence of bearing wear. The belt is in good shape, too. I'm going to inspect the discharge filter as suggested.
  • opinionated Jul 01, 2008
    My PAV2300 washer fills with water but when it should agitate to wash the clothing, an electrical hum ensues instead. I've also notice a mild scent of electrical burning. This occured for the first time 35 days ago. I paid an applicance repairman to come to our home and service the washer but-as some of you have indicated-he couldn't find anything wrong. The machine actually began to agitate after he reassembled the unit! He told me that he'd come back without an additional $30 fee within 30 days if the problem reoccured; as indicated before, this is day 35 and I'm not happy. He's returning next Tuesday; however, after reading the solutions at this site, I'm feeling fairly confident that my husband and I can fix it ourselves. Thanks!
  • heathergwood May 11, 2010
    Our Maytag Performa pav2300 does not spin fast enough to drain all the water.
  • Anonymous Mar 22, 2014
    will not spin
  • Anonymous Mar 28, 2014
    sometime the washer will spin but other times it will not.
    President:
  • 1,294 Answers
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 26, 2007
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
SOURCE:
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
My Performa PAVT920AWW washer will fill with water, but won't agitate. It will spin but has a funny burning smell.
might b motor fault or jammed gearbox.when motor turns one way it drains and spins, when it turns other way it agitates,might b jamming when it turns for agitate.try looking under unit and remove belt, then turn main drive pulley by hand clockwise then anticlock to see if it is jamming. turn power off first dont want any accidents.please reply to see how u go.good luck
Apr 08, 2010 | Maytag Performa PAV2200
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Maytag PAV2300 Top Load Washer Logo
683 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
