Tascam 112 runs in fast forward when I push the play button and the deck sounds like it's in "cue" mode.
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
robotek
  • 1512 Answers
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Posted on Feb 14, 2008
SOURCE: Tascam 38
No way to fix a bad pinch roller.Buy a new one from Tascam 323-726-0303 ex.840 is the parts dept.
Posted on Apr 18, 2008
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
  • 5 Answers
SOURCE: Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
i have the same deck with same problem..so this is the typical problem for this deck...got it from thrift shop..it was in perfect condition, working excellent but after few days of enjoying it, all of a sudden the same problem arises.... and the motor is abnormally hot..it is way too fast.
when i switch on the power the middle motor will automatically turn on at very high speed...i play around anything i can do hoping something is just stuck up but to no avail..
Posted on May 19, 2010
Tascam 112 Front L/R inputs...
Do you have a manual to help you with this
Jan 25, 2014 | Tascam 112 Cassette Deck
Tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
Hi James,
I am a past Teac Technician. The answer may be a bad capstan belt- is the round metal thing rotating that makes contact with the rubber Pinch Roller? These belts become lose over time and the DC motor become defective in time due to wear- Before they burn out they can be serviced but only by a person with knowledge about how to take them apart. Otherwise the part can be $120 plus installation. I have not seen sticky Pinch Roller linkages in these models so I will say it is probably not that.
If you are near Chicago I can help you out. If you are near New Jersey Russ can help. If you want to discuss, contact me.
skywavebe@sbcglobal.net
I work on all Teac and Tascam units now full time.
I am also known on tapeheads.net as well.
Oct 31, 2012 | Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
Tape heads are stuck will not disengage. transport will rew and fast forward but will not play or record. also could not eject tape. unit is a tascam porta one mini studio.
There is a cam system in the transport and they need to be lubricated. It might cost more than $100 to fix. Sometimes the gears have rounded off teeth that you can not get anymore.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
Left deck doesn't "play" anymore.
There is a mechanism problem in the Pinch Roller part of the deck.
It needs to be looked at by a Technician to correct.
Feb 24, 2011 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I have 2 and neither will play a tape. When you press play both make a strange noise
Is it the same tape every time or all tapes? If it is all tapes then it's more than likely a belt issue. The tape players have little rubber belts inside they sometimes get stretched when they are used alot. And they will make a whinning sound. They can be replaced.
Dec 12, 2009 | Tascam 112 MKIII Dual Cassette Deck
Tascam 122 cassette deck the cassette player won't play
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 38
Apr 10, 2008 | Audio Players & Recorders
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
63 people viewed this question
 Grubhead
Grubhead
