Question about Toshiba TEC BSX5 Thermal Label Printer
Command 2 C5.6 - Toshiba TEC BSX5 Thermal Label Printer
P0753, p0758 and p91860 what's my problem and how do I fix it?
Your best bet would be to take your vehicle to a ASE certified professional . You do not have the tools to diagnose this or the information.
DTC P0753
The 1-2 shift solenoid (1-2 SS) valve controls transmission fluid pressure acting on the 1-2 shift valves to position the valves for the appropriate gear. The 1-2 SS valve is a normally-open exhaust valve located on the control valve body. A fused circuit supplies ignition voltage to the 1-2 SS valve. The PCM commands the solenoid ON or OFF by switching the ground path. When the 1-2 SS valve is commanded ON, the PCM senses low voltage. When the 1-2 SS valve is commanded OFF, the PCM senses high voltage. Refer to Shift Solenoid Valve State and Gear Ratio .
If the PCM detects a continuous open, short to ground or short to power in the 1-2 SS valve circuit, then DTC P0753 sets. DTC P0753 is a type B DTC.
DTC P0753 sets when one of the following conditions occurs for 5 seconds:
Condition 1 The PCM commands the solenoid ON and voltage feedback remains high, B+.
Condition 2 The PCM commands the solenoid OFF, and the voltage feedback remains low, 0 volts.
DTC P0758
The 2-3 shift solenoid (2-3 SS) valve controls transmission fluid pressure acting on the 1-2 and 2-3 shift valves to position the valves for the appropriate gear. The 2-3 SS valve is a normally-open exhaust valve located on the control valve body. A fused circuit supplies ignition voltage to the 2-3 SS valve. The PCM commands the solenoid ON or OFF by switching the ground path. When the 2-3 SS valve is commanded ON, the PCM senses low voltage. When the 2-3 SS valve is commanded OFF, the PCM senses high voltage. Refer to Shift Solenoid Valve State and Gear Ratio .
If the PCM detects a continuous open, short to ground or short to power in the 2-3 SS valve circuit, then DTC P0758 sets. DTC P0758 is a type A DTC.
Conditions for Setting the DTC
DTC P0758 sets when one of the following conditions occurs for 5 seconds:
Condition 1 The PCM commands the solenoid ON and the voltage feedback remains high, B+.
Condition 2 The PCM commands the solenoid OFF and the voltage feedback remains low, 0 volts.
What's this p91860 , no such code .
Apr 02, 2016 | 2003 Pontiac Aztek
How to shut off Bluetooth in my gmc Yukon
Using the
Delete
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Delete.
3. Say the name tag you want to
delete.
Using the
Delete All Name Tags
Command
This command deletes all stored
name tags in the Hands
Free
Calling Directory and the OnStar
Turn
by
Turn Destinations Directory,
if equipped.
To delete all name tags:
1. Press and hold
b
g
for
two seconds.
2. Say
Delete all name tags.
Listing Stored Numbers
The list command will list all stored
numbers and name tags.
Using the
List
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Directory.
3. Say
Hands
Free Calling.
4. Say
List
Dec 23, 2014 | GMC Yukon Cars & Trucks
Cannot format my 2 gigabyte usb
Start ->Run -> Cmd .Hit enter button.
Then command prompt will appears on the screen.By using format command you can format your flash drive. Then type format D: /FS:FAT32 Here D is a drive letter.More information about format command in command prompt type help format.
Aug 03, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
What is command? where is the answer in english?
1 com·mand verb \k??-??mand\
Definition of COMMAND
transitive verb
1: to direct authoritatively : order
2: to exercise a dominating influence over : have command of: as a : to have at one's immediate disposal <commands many resources> b : to demand or receive as one's due <commands a high fee> c : to overlook or dominate from or as if from a strategic position <a hill that commands the city> d : to have military command of as senior officer <command a regiment>
3obsolete : to order or request to be given
intransitive verb
1: to have or exercise direct authority : govern
2: to give orders
3: to be commander
4: to dominate as if from an elevated place
2 command - noun
1a : an order given b : a signal that actuates a device (as a control mechanism in a spacecraft or one step in a computer); also : the activation of a device by means of such a signal
2a : the ability to control : mastery b : the authority or right to command <the officer in command> c (1) : the power to dominate (2) : scope of vision d : facility in use <a good command of French> e : control 1d <a pitcher with good command of his curveball>
3: the act of commanding
4: the personnel, area, or organization under a commander; specifically : a unit of the United States Air Force higher than an air force
5: a position of highest usually military authority
3 command - adjective
: done on command or request <a command performance>
First Known Use of COMMAND
1826
Jul 30, 2011 | Datsun Maxima Cars & Trucks
I need serial number for command & conquer red alert 2
please help lost the 22 digit serial number to command & conquerred alert 2 to install on my laptop
Nov 23, 2010 | West Wood Studios Command and Conquer Red...
Logitech Harmony One remote is controlling 2 TiVOs at once.
Please try learning the some commands from one of the original remotes for thr tivo. If this fixes the problem, i suggest that you learn all commands from that remote.
Launch the Logitech Harmony Remote software and login to your account
1. Click on the Devices tab
2. Click on the Learn IR button for the device you want to learn command(s) to.
**NOTE: When learning new commands, there are three different options available:
-You want the Harmony Remote to learn a single command that is already listed in the software
-You want the Harmony Remote to learn more than one command at a time
-You want the Harmony Remote to learn a new command, which is not listed in the software
a. Click on the Learn button next to the command you want to learn - Proceed to Step 5
a. select one or more commands by clicking on the check box next to the command(s) you want to learn and then
b. click on the Learn Selected Commands button
c. Proceed to Step 5
You want the Harmony Remote to learn a new command, which is not listed in the software:
a. Scroll down to the button of the page
b. In the Learn a New Command box click on the text MyNewCommand
c. enter the name of the command you would like to teach.
d. Click on the (Learn New Command) button
e. Proceed to Step 5
5. Follow the onscreen directions for learning commands, plugging in your Harmony remote when asked and lining up your original remote to the Harmony as illustrated on the screen.
6. When a command is successfully learned, a check mark will appear next to it. If learning more than one command, the software will then prompt you to learn the next command.
7. The commands that were learned should now be identified as from "Your original remote" and highlighted in turquoise.
8. When you have finished teaching the commands, click Done button to save your changes
9. Click on the Update Remote button to update your remote
If this does not work, try :
To teach commands for your Device that did not work properly in normal mode:
1. Click the Devices button on your home page.
2. Select the Device you wish to learn commands to.
3. Select Learn Infrared Commands.
4. Click Custom. The page will reload.
5. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
NOTE: When teaching each command, press the button on the original remote for as long as required to control the device. The commands will be learned with the exact format that is sent by the original remote.
If you have any trouble teaching the commands in RAW, complete the following steps:
1. Verify you are pointing the original remote at bottom end of your remote, and are holding the remotes 2-4 inches apart.
2. Minimize the amount of light that could interfere with the learning process by covering the distance between the remotes. Block out sunlight, or turn off the lights.
3. Check that you have installed new batteries in the original remote you are trying to use to learn commands. If the batteries are low, the signal coming from your original remote may be too weak for the remote to detect.
4. Be sure to hold down the button on the original remote for at least 1-2 seconds, otherwise the signal may be too short for the remote to process.
5. If you continue to have trouble teaching the commands, start with the remotes 2 inches apart. Then try again with, slightly increasing the distance each time (2.5 inches, 3 inches, etc).
6. Vary the angle at which the original remote is pointing at the bottom of the remote.
7. Ensure the device's original remote is sending infrared (IR) commands.
NOTE: The original remote is sending RF or UHF commands from the original remote if it will control the device from another room, through a wall).
Oct 04, 2009 | Logitech Harmony One Advanced Universal...
How do I retrieve my voice mail when I'm away from home?
this instruction may help you , if not a model number could help , but try these instructions . thanks
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 57).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following chart:
Remote Commands
Command 0 then 1
Repeat a Message*
Command 0 then 6
Answering Machine On
Command 0 then 2
Playback Messages
Command 0 then 7
Memo Record/Stop**
Command 0 then 3
Skipping a Message
Command 0 then 8
Greeting Record/Stop**
Command 0 then 4
Deleting a Message
Command 0 then 9
Answer Machine Off
Command 0 then 5
Stop Operation
Command 1 then 0
Help Guidance
we can get a link to your manual if we had model number
Dec 30, 2008 | Uniden 5.8GHz Dual Cordless Phone
Gears of war problem
Simple fix for forward-back movement axis inversion:
In "My Documents\My Games\Gears of *** for Windows\***Game\Config", edit the file "***Input.ini". At the very top, under the section "[Engine.PlayerInput]", change your MoveForwardSpeed to a negative number, like this:
MoveForwardSpeed=-1200
Note that I only play offline, and this setting in this file works great for me with Logitech Rumblepad 2 (although all of the other buttons are still a little off, but that I can live with). I tried every other reference to forward-backward movement and the left Y axis in this file, as well as "<installdir>\Engine\Config\BaseInput.ini" and "<installdir>\***Game\Config\DefaultInput.ini", so don't bother with those...
Dec 08, 2007 | Logitech Rumblepad 2 Game Pad
Blue patch
you didn't state how many hours are on the unit, but I'm guessing close to 3,000 hours, that is when most brands have LCD panel failures, due to the heat over time the coating on the lcd panels burns off, the panels start to burn up, and it gets worse with time, and you notice it more when you put a fresh bright lamp in. if it is low hours then you could have a bad lamp, that casts a bad tint, but it sounds like fried LcD panels, a sure way to tell, is put up a white back-ground screen and see if you see discolored "BLOB" in the center of the screen.
keeping the filters clean, and the projector cool is the best way to prevent this.
Nov 09, 2007 | Hitachi PJTX100 Multimedia Projector
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Toshiba TEC BSX5 Thermal Label Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
