Toshiba AW 1170 SB Washing machine E 2 coming what is the problem?
4 Suggested Answers
kalamazoo222
  • 285 Answers
SOURCE: i have TOSHIBA AW 8500
Toshiba does not seem to support washers in USA. You should go to Toshiba worldwide support at http://www.toshiba.co.jp/worldwide/index.html. Select your country and follow the steps to get a phone number. Talk to a CSR and they should be able to give you a part number and/or dealer near you.
It sounds like you need the Lint trap for your Toshiba AW 8500S washer. Good luck!
Posted on Nov 29, 2010
  • 6277 Answers
SOURCE: My washing machine modle toshiba
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 27, 2011
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
My toshiba washing machine aw-9500 SB showing error E9. what is the solution???
Check that the level of the drain hose is not lower than the base of the washing machine. Additionally check for a water leak. If no trace of water, switch off the power, reconnect and try again.
Jun 10, 2016 | Washing Machines
Toshiba washer malfunctioning model aw 9770 sb showing an error of e7-4
Owner's manual troubleshooting may give you an answer.
Google make model possibly serial year. You may find someone with the same problem and the solution. Usually MFG customer service is helpful. If fairly new local dealer may be helpful.
Mar 08, 2015 | Washing Machines
Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
Feb 09, 2015 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
I have TOSHIBA AW 8500 S washing machine... there is one part which located inside washing tub (part with net) where all dust nd all accumulated during washing, is comppletetly destroyed.... i want want...
Nov 29, 2010 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Sep 09, 2009 | Washing Machines
Washing Machines Logo
220 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
