Question about Samsung Dishwashers
Samsung dishwasher low rise stays on and wash cycle but doesn't wash
  • 38 Answers
SOURCE: THE DISHWASHER STAYS IN THE WASH CYCLE
Check to see if the water is getting hot during this time, if not then the heater is probably not working, could be bad heater, bad door switch or bad heater relay on the control board.
Posted on Feb 23, 2009
gary1121
  • 332 Answers
SOURCE: dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
Posted on May 30, 2009
localwonder
  • 6784 Answers
SOURCE: dishwasher wont go through the cycles
Hi. this will occur when the timer control or control board has experienced a major fault within the circuitry. in most cases, the actual timer mechanism will fail. this will stop the forward advancement of the wash cycle.
Total replacement of the timer control module or control board will fix this issue.
Posted on Jul 19, 2009
rylee_smith
  • 8619 Answers
SOURCE: My dishwasher keeps washing, doesn,t go through
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 27, 2009
  • 949 Answers
SOURCE: My dishwasher is seeming to stay on the wash
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Posted on Apr 25, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
Samsung dw does not advance to next cycle
Does it work properly if you advance the switch through the cycles by hand? If yes, the cycles are all fine, the timer motor that drives the timer is bad.
Aug 14, 2014 | Samsung DMT300RFS Builtin Dishwasher
Problem with wash tower of GE GSD2200G00ww not rising up
if the tower isn't rising DURING the wash cycle it is most likely caused by one of 2 issues. 1 being too low of a water level which can be caused by low flow thru the pipes, blocked filter in the inlet valve, or a bad inlet valve. The 2nd cause can be low pump pressure due to the main food shredder screen, located below the large plastic "filter" in the rear right-hand corner, being plugged with garbage. The valve can be replaced if needed, the filter can be cleaned w/o removal of the entire unit, but if the water flow is low, you will most likely need a plumber.
Nov 22, 2012 | GE Nautilus 24" Built-in Dishwasher
Stuck on low rise
If you cannot change the rinse cycle setting, then the control panel might be faulty or damaged. Since you are the second owner, you have no warranty so you would need to contact a local professional to take a look at it.
Sep 06, 2012 | Electrolux EWDW6505GS Fully Integrated...
Drain stays open after start so water doesn't stay in dishwasher for wash cycle. Model GLDT696TSS
Looks like a pressure switch problem. Refer part 26 in this diagram. The drain pump operates instead of the wash pump.
Sep 22, 2011 | GE GLDT696TSS Builtin Dishwasher
My dishwasher wont drain.. water stays in the tank..
When you run a dishwasher, there is usually food particles left over from a cycle. First thing is to check the lent screen. The lent screen is located on the bottom usually in the back of the dishwasher. If you want to put some gloves on and remove it and turn on the drain cycle on your dishwasher. If that doesn't do it turn off the power to the dishwasher by the breaker box, and check your hoses inside the dishwasher.
May 11, 2011 | Maytag 24 in. Built-In Dishwasher w/...
Kenmore dishwasher water will not stay in there
It sounds like you have a drain hose problem. The drain hose needs to have a rise in it. If it is going down hill or to a drain that is lower than the tub it can drain as fast as it fills.
Apr 24, 2010 | Kenmore Dishwashers
Dishwasher wont start washing but start light is flashing 11 times
hi...
The cause of the problem is an insufficient rise in water temperature during a pre-set time period. The heater fault-detection program that was added to the electronic control is designed to shut down the dishwasher if the board-test for proper water temperature rise is not sufficient.
The dishwasher run cycle was modified to add 8 minutes 45 seconds of heat at the beginning of the main wash cycle. If the inlet water at the thermistor is below 110°F, the thermistor looks for a water rise of 4°F. If the inlet water is over 110°F, the test is for an increase of 2°F. If the temperature rise is below specifications, the unit will drain and the clean light will blink seven times.
You will need to identify possible causes of insufficient temperature rise. These causes may include checking the wiring to/failure of the control, the heating element, the thermistor, the inlet valve, door switch, motor or capacitor. Make sure that water is not siphoning during fill. Once the heater fault detection is triggered and the condition resolved, the electronic control must be reset by initiating a special diagnostic cycle. Use the Product Tech Sheet shipped with each dishwasher — you’ll find it behind the kickplates — to identify the correct cycle sequence. The rapid advance cycle will not properly reset the electronic control....
thank u
rate me
Jul 22, 2009 | Dishwashers
Dishwashers Logo
61 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
