Power supply model no:fsp026-2pi01 fuse not blown,but doesn't switch on,i also change the capacitor ,still the same,any ideas what the fault is
5 Suggested Answers
sys_admin
  • 829 Answers
SOURCE: Power down during boot up.
How can I help you, Please let me know which place are you from.
Posted on Dec 17, 2008
falter
  • 245 Answers
SOURCE: i need a power supply for this unit, the capacitors on mine have blown
go to ur pc store they will have a new one waiting for u......
Posted on May 22, 2009
Geekman
  • 32281 Answers
SOURCE: Blown capacitor in a Veriton 3600G...psu runs but system will no
It is not unusal for capacitor/s to blow their tops and could emit flames and smoke as the power supply ages. When they blow they could damage other components. Don't bother trying to replace them, get a new power supply.
Posted on Oct 06, 2009
Testimonial: "Rapid response and easy to understand."
rmgb98
  • 3 Answers
SOURCE: Beeping Noises When Power Is On
Sounds like a faulty power supply or the wire going in/out of it. Try moving the wire and see if that gives you a good connection.
Posted on Jun 13, 2012
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
TV NO POWER?
Any bulged capacitors? If so- they caused the fuse to blow. If nothing is obviously showing fault, check the capacitors in the main portion of the power supply for shorted condition. Also look for failed resistors, and shorted TVS
Dec 20, 2011 | Televison & Video
I have a westinghouse sk32h240s. wont turn on and no amber light.
First try a new power cord for the TV. If that doesn't solve the problem, the power supply has failed. (Possibly one or more capacitors on the power supply board have failed. Alternatively, a fuse, zener diode or resistor that works as a fuse has failed) You will need to open the tv and inspect the power supply. Westinghouse TVs use a number of different boards. If you want to replace the entire power supply, you will need to note that exact part number on the label. ShopJimmy has refurbished and used power supplies for this model: http://www.shopjimmy.com/westinghouse-sk-32h240s . The used ones are from TVs that were damaged in shipping and thus have minimal use. http://www.partstore.com/Model/Westinghouse+Digital+Electroni/Westinghouse+Digital/SK32H240S/Other+Remotes.aspx also has replacement parts.
I hope this helps.
Oct 03, 2011 | Westinghouse SK-32H240S Television
SCX-4200 printer - no power in machine, no display, but power definitely going in. Any ideas please?
It is most probably a problem with the power supply inside the unit. If the unit switches on, but black squares appear on the display, it is a capacitor that is blown (most probably a 10v 1500uF capacitor) otherwise if the unit does not power up at all, the fuse on the power supply has blown.
Sep 25, 2011 | Samsung SCX 4200 All-In-One Laser Printer
The TV doesn't power on. I've changed the fuse and when mains power is switched on the TV makes a noise as though power is getting through. Pressing the standby on the remote has no effect -...
The problem might be on your power supply section.
1. Check for open resistor or maybe a shorted transistor. Use a multimeter
2. Also check for a leak capacitor
Is the fuse you replace is still o.k? at times the blown fuse indicates that there is a short circuit on your t.v. Maybe the noise you hear is also because of a short circuit. Be careful in replacing fuse, always replace same type for the protection of you t.v
Hope this may help you
Aug 20, 2011 | Televison & Video
No power coming out of the power supply. Most of capacitor were changed, but it didn't help.
Check your fuse on the power supply. If it is blown, change it with same value fuse and hope it doesn't blow again. If it does, or it wasn't to begin with, then you need to replace your power supply.
Apr 19, 2011 | LG 37LC2RR 37 in. LCD TV
Clicking noise will not power on, changed 2 blown capacitors. May need eeprom re-set sounds complicated?. many thanks
IF THETWO BLOWN CAPS WERE IN YOUR POWER SUPPLY REPLSCE THE POWER SUPPLY SOMETIMES EVEN WHEN WE CHANGE THE CAP
THE POWER SUPPLY IS BAD
Jun 03, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Humax 5400 satellite receiver ,power suppl problem
Dear Robert...
I think the problem with my humax 5400z is similar to yours.
Both 5400 & 5400z have the same power supply unit.
I just solved it this evening by changing C9.
It's a 1500 μF 10V electrolytic capacitor. Be careful not to reverse the polarity my friend.
If you have problems to find the capacitor just e-mail me at rel@link.net and I'll send you pics showing the location of that C9 capacitor on tthe psu board.
Hope this could help you.
Good luck.
Ramez Lebbad.
Dec 04, 2008 | Audio Players & Recorders
No power
Hi Nikadis your problem is shorted,when you going to change new fuse its blown away.The diodes there in supply is shorted change that ,and the capacitor also short look it up.If you do this your unit will come on.message me whatever the result.
Jun 17, 2008 | Sony LBT-G3300 Shelf System
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
