Question about Refrigerators
My roper model is RT18AKXKQ05, not listed on this site. This refrig is only 6 yrs. old. It has stop going through the cycles. I check on it every day. Most of the time it is not running. So I turn the temp control one way or the other, and it starts up. Then it will run for a bit of time, and evidently it cuts off. Give some kind of solutions for this, thanks.
    Problem Solver:
  • 19 Answers
It could possibly be low on a freon charge.
Posted on Apr 23, 2009
Roper refrig 9 yrs old..rt18bkxkq00..started blowing warm air 2 days ago..both freezer and refrig....turned off for 24 hrs to completely defrost and still not cold..hear intermittent clicking noise by...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
Washing machine works up to the spin cycle, it does not spin it does however empty the water. this is a roper brand top load machine about 5 yrs old.
Lid switch. A safety mechanism used to make sure lid is closed in spin cycle. You can bypass this switch by placing the wires that go to switch together. DO NOT do this if you have children or do not want to remove that safety feature some require because they dont know better than to open a washer in spin cycle. :)
Jul 07, 2010 | Roper RAS8445KQ Top Load Washer
My Roper model #RT18AKXKQ05 is leaking water into the refrigerator from the freezer via the part in the back of the freezer. I can't find any help in the Use and Care Guide? What do I need to do in order...
it sounds to me like the drain is plugged in the freezer. When the freezer goes into defrost the water vapor gets pulled up by the fan and blows into the fresh food side via the air baffle in the back of the fresh food side. Take the back cover off the freezer and break up the ice and pour some hot water down the drain and if you have a small hose to shove down the drain and that will help you out as well...good luck!!!!
Oct 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Won't run
ensure your door switch is working then move into timer.
May 05, 2009 | Roper RES7646KQ Electric Dryer
My dryer belt broke
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. There are numerous dryer belt diagram illustrations listed that you can print out. Admiral is listed. I hope this helps you.
Nov 12, 2008 | Roper REX3614KW Electric Dryer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Roper washer issue
next time it stops raise lid on right side at edge of opening will be a small opening where lid switch is push down switch with pencil or something small enough to fit if it starts working replace switch ..if switch is not at that location may be under hinge left rear if that is the case ck hinge screws
Aug 20, 2008 | Roper RAS8445KQ Top Load Washer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
