Question about Dell 1210S DLP projector 2500 ANSI lumens SVGA (800 x 600) 43 with 2 years Advanced Exchang Projector
The projector is mounted upside down and I need to invert the image. cannot find the option on the menu. can someone describe the pathe to this option in the menu
4 Suggested Answers
  • 141 Answers
SOURCE: Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Posted on Aug 05, 2009
c1apton15
  • 3400 Answers
SOURCE: Hello, please tell me how to flip the image upside
Go into projectors menu, and you'll find sub menu "display" and it will give you options front, rear, etc and choice front, ceiling
Posted on Mar 15, 2011
m_peel
  • 76 Answers
SOURCE: My dell 4610x projector is
There is usually a section for the orientation of the projector, maybe the ceiling/table mounted section is in a differnent place in the settings menu than the front/rear facing section.
Good luck
Posted on Aug 05, 2011
UPSIDE DOWN IMAGE TLP261 LCD
You need to get into the menu, there is an invert image option as the projector can be mounted upright or upside down depending on the mounting of the projector
Mar 08, 2012 | Toshiba TLP 261 Multimedia Projector
I mounted the projector on the ceiling and need to flip the image
ok go in the main menu u see 4 windows under on eof the options flip throw the windows to get it to go right side up ok in menu settings on the sony ok
Feb 02, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Projector is suspended from the ceiling upside down and so it is projecting upside down. How do i get it to project the images the right way up?
Since you have not mentioned the model it is diffficult if the option of reverse image is available on the menu. If so all you need to do is to scroll the menu and reverse/invert this image. If not the other option is to mount the projector with the projector fitted on a small stand in the same direction and not invereted. I hope you will search for this in the menu or in the rear panel. If not mount it in the actual position with a stand so that you can corrrect the height using the provided screw adjusters.Helpful? Good day
Jul 07, 2010 | Audio Players & Recorders
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Image upside down
Check in the settings. One of them will have the option to invert the image not sure what it will be called. That should flip it upside right. I had the same issue with my projector when I first got it just messed with menu until i found it.
Feb 11, 2009 | Epson (V13H010L13) Projector Lamp for...
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
Dell 1210S  DLP projector  2500 ANSI lumens  SVGA (800 x 600)  43 with 2 years Advanced Exchang Projector Logo
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
Jerry Umali
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
