Question about Dell 1600n All-In-One Laser Printer
Dell 1600N fuser replacement
Hello after I print a document the ink was smearing on the pages, I called Dell technical support they said I need a new fuser, I ordered the part but there are no instructions how to install. Does anyone know how to install the fuser? Thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
1. Power Printer off and disconnect power cord.
2. Remove back cover.
3. Remove rightside cover
3. Disconnect the thermistor cable from the controller card. (rightside)
4. Disconnect the power cable from the power board. (bottom back of the printer)
5. Remove the 4 screws securing the Fuser assembly to the chassis.
6. Pull fuser out towards you.
7. Reverse the previous steps to replace the fuser.
Posted on May 07, 2009
When documents print out, one side of the copy is smeared. We cleared out a paper jam and I think part of the lining of the roller came off.
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Mar 29, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
My Dell 1600n Laser Printer gives message Open Heat Error
Just call Dell Tech support. It's in their policies that if you call them and complain about a heat issue, they'll replace the unit for safety reasons.
Cheers.
Dec 07, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Ink doesn't dry
Your fuser is not functioning correctly. You will need to replace it. The toner has to be heated by the fuser to make it bond to the paper. Look at this forum for the part numbers.
Mar 26, 2009 | Dell 1600n All-In-One Laser Printer
Print smear
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Oct 15, 2008 | HP LaserJet 1100 Printer
Paper jam, Is this the fuser?
I have had the same problem. Changing the fuser is easy (about $85, and must be ordered through Dell) remove the 4 screws from the back, and you'll see the fuser. 2 screws, and 2 wires, and it slides right out.
Jul 16, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Print jobs smeared
Hi Are you using OEM or rebuilt toners? If your using OEM and your able to smear the ink with your finger more than likely you have a fuser problem?. If your using rebuilt cartridges it could be the cartridge. Good Luck!!
Nov 28, 2007 | HP LaserJet 2550L Printer
Dell 1600n All-In-One Laser Printer Logo
1,317 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
