Question about EliteGroup P4M800PRO-M Motherboard
Mondeo sticky handles
I,ve hade 4 mark 1 mondeos all have had stickey handles ie not springing back only happens on two back doors not front ones is this a mondeo only problem tried wd 40 doesn,t really help
  • Anonymous Mar 06, 2009
    Exactly the same Problem I have Anyone have a straightforward solution?
PLSM, PLS, PLS, PLS, PLS
Posted on Feb 23, 2008
SOURCE:
How do you change a passenger door handle
hope this helps passenger similar. Removing interior panel depends on vehicle
May 10, 2016 | 2008 Ford Mondeo 2.0
I have a mondeo 2.0l serve x the 2000 car I can open the front drivers door with the key or fob passenger door I have to use the key but both back doors wont open at all they are deadlocked it seems t
Are you saying they won't unlock with the power unlock or that they cannot be opened from the exterior and interior handles? If you can't open with either latch, then there is a mechanical problem with both doors. If you add info or clarify, please add to original question via comment.
Jan 06, 2015 | Cars & Trucks
Mondeo central locking
Try a new battery in the KEY
Jul 09, 2014 | 2003 Ford Mondeo
How do i change a front spring on a ford mondeo 51 year
You need a special tool to do this, best to change both, one will cause handling unbalance issues.
Jun 11, 2014 | 2003 Ford Mondeo
Ford mondeo car radio code 2006 titanium x
try entering the code then press button 5 to enter the code ,then write the code on the back of the sunvisor ,them cards get lost or the dog or the baby chew them up ,
Aug 20, 2013 | Sony Car Audio & Video
I'm looking for a diagram of the timing chain and timing marks for mondeo st 220?
Duratec ST-220 used in the top of the line Mondeo 3.0 liter V6.
The original Duratec V6 was introduced in Europe in 1993 in the Ford Mondeo (Ford Contour/ Mercury Mystique in NA). Then in 2000 the smaller 4 cyl Mondeo engines also got the Duratec name, as well as others. Check this for 3.0L 6cyl...
Fig. Be sure the timing marks are as shown after the chain has been installed-2001-04 3.0L (VIN S) engine ( zoom link here )
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 15, 2012 | Cars & Trucks
Ford Mondeo rear brake pads replacement
I have ford mondeo ghia 2002.
when i press the button on the remote-key, I can lock and unlock the powerlock (in the door).
When I press the button un the door, not all doors are locked.
What's the reason?
thnak's
Sep 17, 2009 | Cars & Trucks
Keys locked in mondeo!!!!
no spare keys ???shame on you ,these cars take me 2/3 mins max to open ,pull back top of door with two big screwdrivers using a bit of rag to protect paintwork,then with a thick piece of metal rod about a least an 1/8 with Lshape on the bottom to turn pull handle outwards,its a doddle
Jan 27, 2009 | 2000 Ford Focus
Auto door locking on Ford Mondeo
It sounds like it has been deactivated so we are going to reactivate the auto lock.
The numbers I will be saying will have to do with getting this to work so:
you will need to put the key in to the ignition switch.
1= is back to listen to the radio
2= is to get key out
3= is just before you start
4= is for starting your car
When we do this 1 and 4 will not be used
Do this and we will hope that it works like it should:
1: Turn the ignition with you key up to on( don't start)
2: Press the power door lock control 3 times
3: now turn the key back once (to off position)
4: Press the power door unlock control 3 times
5: ok turn the ignition back up 1 time. (The horn should chirp)
6: Then press the unlock control, then press the lock control, again (horn will chirp 1's) If auto lock
was activated.
7: Turn the ignition back 1's, Then the horn should chirp once to confirm the procedure was completed.
Nikki2913
Nov 23, 2008 | 2006 Ford Focus
EliteGroup P4M800PRO-M Motherboard Logo
131 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
