Question about Cycling
I have a Polaris Vector Electric Bike. Power cuts out at random times. I can remove and reinstall the battery and it will start working again, or i can manually pedal and it will start working after a few minutes. On some rides it can happen 5 or 6 times, on other rides no problem at all. Need Solutions.
4 Suggested Answers
SOURCE: electric bike cuts out while riding
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
Posted on May 03, 2009
  • 21 Answers
SOURCE: Intermittent failure of hr detection
Several issues with the Polar unit, 1 if it is in the cold the unit does not work properly. 2. If your layering yourself the unit will not work properly. 3, If the unit is not place properly on the body and there is not sufficient moisture, the unit will not work properly.
The best that I can suggest is make sure that you have sufficient moisture on your body, hold the polar cs100 near your body till it detects a heartbeat, the place back on the bike.
If your layering do to weather, you may not get it to respond till spring. I know what a waste.
By the way I had the CS 200, and I can't begin to tell you how many of my riding buddies had the same issue that your talking about including me.
The situation with polar rarely has to do with with interference but with a weak transmitter.
Posted on Oct 13, 2009
Testimonial: "Thanks I am riding tomorrow and will do some checks based on your layering ideas."
SOURCE: Hello i have a Sakura s305 electric bike, can you
when you insert the key to switch it on ,push a little harder and turn key backwards and it releases the battery pack
Posted on Jul 24, 2011
Electric bike not starting
If the motor don't start could be for many reason, but I have this problem too and what I find out was that the brake cut power cables who order to the motor not to run when you brake, are doing this even when the bicycle isn't operating, and once I disconnect the brakes from the controller the power return and I can ride the bike again, but doing this on my bike the cut brake function is missing, the one I will like to know how to fix if some body there knows how.....
Sep 13, 2013 | Electric Bicycle Motor, Bike,electric...
400 polaris xplorer 4x4
Hey Randy,
Sounds like the battery needs to be replaced. Take the battery to O'Reilly, Autozone, Advance Auto and have the CCA, (Cold Cranking Amps) checked..(load test).. this will tell you whether the battery is good or not. When you get a new battery.. make sure the connections are clean and tight..put a little heavy grease on the connections to prevent corrosion. This should fix your problem.
Aug 29, 2017 | Polaris ATV
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
Polaris 425 magnum lights don't work. how do I troubleshoot
GET A 12 VOLT TEST LIGHT, AND LOCATE YOUR FUSE BOX AND CHECK THE WIRES UNDER THE HEADLIGHT. TEST LIGHT IS YOUR BEST FRIEND.
Oct 25, 2011 | Polaris ATV
HELLO.. MY DAUGHTERS POLARIS TRAIL PRINCESS STALLS WHILE GOING UP HILLS. THE BATTERY SEEMS TO CUT OUT, AS THOUGH NOT ENOUGH POWER TO MAKE IT UP A SMALL INCLINE.. I CAN UNDERSTAND THIS, HOWEVER THE BIKE...
sounds like the foot pedal might be bad, when she is driving forward and lets off of the pedal do the rear wheels lock up or does it keep coasting?
Jul 05, 2010 | Polaris Trail Princess
Override switch issue
sounds like it thinks it stuck in reverse
Aug 09, 2017 | Polaris ATV
Fault with electric start on my Suzuki GSF 250 Bandit
Check that the clutch is in, kick stand up, and neutral light ablaze. Then try your start button. When you had it running and hit the button, the starter engaged at a slower speed then the bike engine was turning, which led to the stall. The stall means your starter works. If the starter works when the engine is running then it is wiring. Check your kick stand wiring along with the clutch wires which plug in on the handlle bar or where the clutch cable enters the engine.
Oct 18, 2009 | 1995 Suzuki GSF 250 Bandit
Our polaris sportsman 500 6x6 won't start
Polaris seems to have a problem with this issue. I had the same problem with my bike and was able to fix it . I found a bad resetable fuse link located under the front cover. It looks like a plastic case with wires at both ends. cut the case and check the condition of that part. I found it was badly rusted . I removed the part and wired in a 10 amp fuse with a holder. wrapped it up to protect it and the problem was gone. lights worked fine as well as the cluster. Ed.
Oct 11, 2009 | Polaris ATV
Cycling Logo
50 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
