Question about Dryers
My cooling fans only run when I unplug the coolant temperature sensor on the back of the engine by the exhaust manifold. I replaced the sensor but the problem remains the same.
    Scholar:
  • 64 Answers
Information on the year, make and model of car would be helpfull.
Regardless, it sounds like there is either a short between the two wire leads, somehwere in the wiring harness, or there is a broken connection, causing the ECM to think that the car is always cold.
Posted on Oct 18, 2013
2006 chevy Silverado Electric cooling fans do not come on. Replaced all relays. Checked the fans by hot wiring them to the battery and they function. Other than the PCM what else could it be?
Did you check the fuses, any voltage at the fuses? In the picture, the left side of relay is control, the pcm grounds the control side of relay. Any applicable trouble codes? Check the coolant temp sensor. I'm not saying replace anything. Will the fans come on if you turn on the ac?
The fans should come on around 220 degrees F. Some makes and models, if you unplug the coolant temp sensor, the fan/s may run all the time? The info I looked at was for 1500--5.3L engine--non-hybrid.
Feb 17, 2017 | Chevrolet Silverado Cars & Trucks
Cooling fan running slow all the time what to do to fix?
Disconnect the fan and apply 12volts to it and see if runs on high or measure the voltage on it with a meter. If it has low voltage you need to replace the fan module
Jun 03, 2015 | 2005 Nissan Maxima
Where is the 98 Lincoln mark 8 cooling fan relay.
Does it run when the engine is cold, how about with just the key on engine off
Jun 20, 2014 | 1998 Lincoln Mark VIII
Where is the coolant temperature sensor located on 1990 pontiac transport
The Coolant Temperature Sensor is located: Under hood, driver side, upper engine area, front of distributor, mounted in intake manifold
Sep 09, 2012 | Pontiac Trans Sport Cars & Trucks
2000 daewoo leganza is overheating, leaking anti freeze, and water. what is wrong?
sound like thermostat sticking close.replace thermostat and radiator pressure cap.if already done.you could have faulty water pump.if engine overheating at long slow traffic line or setting at a stand still.the engine cooling fans should be running, check and see if cooling fans running if not,check cooling fans fuses and relays.if all is good,hot wire make sure coolings fans okay.if all is good,code scan vechicle for faulty engine coolant temperature sensor and ecm problems.you need a code scanner where you can check live data check see if coolant temperature sensor reading correctly if engine coolant temperature is 190 degrees the coolant sensor. the scanner suppose to show 190 degrees in temperature if not it reads 80 or 90 degrees the engine coolant temperature sensor is faulty need replacing.if all is good check engine oil if look like milk shake blow head gasket will cause over heating.to be on the safe side i would replace thermostat and radiator pressure cap first.to make sure engine coolant circulating through radiator and engine block.
Nov 15, 2011 | 2000 Daewoo Leganza
My 2004 GMC Envoy has two trouble code readings of 106 & 128. But the light will come on for a while then it will stay off for a while. The auto parts compny that should me the readings said it could...
Hello there,. Below is the detailed information which you asked for.
Please do not forget to rate me!!
Best regards
Ck
P0106 - MAP/Barometric Pressure Circuit Range/Performance ProblemOBD-II Trouble Code Technical Description
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
What does that mean? The Powertrain Control Module (PCM) uses the Manifold Absolute Pressure Sensor (MAP) to monitor engine load. (NOTE: Some vehicles have a Barometric Pressure (BARO) sensor that is integral to the Mass Air Flow (MAF) sensor and do not have a MAP sensor. Other vehicles have a MAF/BARO and a redundant MAP sensor where the MAP sensor functions as a backup input in case of MAF failure.) The PCM supplies a 5 Volt reference signal to the MAP sensor. Usually the PCM also supplies a ground circuit to the MAP sensor as well. As the manifold pressure changes with load, the MAP sensor input informs the PCM. At idle the voltage should be 1 to 1.5 Volts and approximately 4.5 Volts at Wide Open Throttle (WOT). The PCM looks for any change in manifold pressure to be preceded by a change in engine load in the form of changes in throttle angle, engine speed, or Exhaust Gas Recirculation (EGR) flow. If the PCM doesn't see any of these factors change while detecting a rapid change in MAP value, it will set a P0106.
Causes A P0106 could be caused by:
  • Bad MAP sensor
  • Water/dirt intrusion affecting MAP sensor connector
  • Intermittent open in the reference, ground, or signal wire for the MAP sensor
  • Intermittent short in the reference, ground, or signal wire for the MAP sensor
  • Ground problem due to corrosion causing intermittent signal problem
  • A break in the flexible air intake duct between the MAF and the intake manifold
  • Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
Possible Solutions Using a scan tool, watch the MAP sensor value with the key on, engine off. Compare the BARO reading with the MAP reading. They should be roughly equal. The voltage for the MAP sensor should read approx. 4.5 volts. Now start the engine and look for a significant drop in the MAP sensor voltage indicating the MAP sensor is working.
If the MAP reading doesn't change perform the following:
  1. With the Key on, engine off, disconnect the vacuum hose from the MAP sensor. Using a vacuum pump, pull 20 in. of vacuum on the MAP sensor. Does the voltage drop? It should. If it doesn't inspect the MAP sensor vacuum port and vacuum hose to manifold for a restriction of some kind. Repair or replace as necessary.
  2. If there are no restrictions, and the value doesn't change with vacuum, then perform the following: with the Key on and engine off and the MAP sensor unplugged, check for 5 Volts at the reference wire to the MAP sensor connector with a Digital Voltmeter. If there is none, check for reference voltage at the PCM connector. If the reference voltage is present at the PCM connector but not the MAP connector, check for open or short in the reference wire between MAP and PCM and retest.
  3. If reference voltage is present, then check for existing ground at the MAP sensor connector. If it isn't present then repair open/short in the ground circuit.
  4. If ground is present, then replace MAP sensor.
Other MAP sensor trouble codes include P0105, P0107, P0108 and P0109.
P0128 OBD-II Trouble Code Technical Description
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
What does that mean? This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolantmag-glass_10x10.gif temperature (ECT) sensor reading, and the speed of the vehicle.
Causes A code P0128 may mean that one or more of the following has happened:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
Possible Solutions Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
  • Verify coolant strength & level
  • Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
  • Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
  • Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
  • If the above items check out good, replace the thermostat
Sep 24, 2011 | 2004 GMC Envoy
I have a code P0128, what is my problem is this in the cooling system?
This code is for your Coolant Thermostat - It's detected that the Coolant Temperature is below the Thermostat Regulating Temperature
This code may mean one or more of the following has occurred:
  • Cooling fan running too much
  • Faulty coolant temperature sensor (ECT)
  • Faulty intake air temperature sensor (IAT)
Check the following to see if it resolves your problem:
  • verify coolant strength and level
  • verify cooling fan operation and replace if necessary
  • verify ECT sensor operation and replace if necessary
  • verify IAT sensor operation and replace if necessary
  • if all above checks out, replace the thermostat
Oct 16, 2009 | 2002 Buick Rendezvous
Radiator fan not working
CHECK FUSE AND RELAY.IF ALL IS GOOD.HOT WIRE COOLING FAN USING JUMPER WIRES.USING CAR BATTERY.IF FAN RUNS.ITS GOOD.IF FAN DONT RUN.REPLACE FAN ELECTRIC MOTOR.ALSO SCAN IT. TO MAKE SURE COOLANT TEMPERATURE SENSOR IS NOT OPEN.MAKE SURE ENGINE COOLANT TEMPERATURE SENSOR AND COOLANT TEMPERATURE READS SAME ON SCANNER IF NOT REPLACE THE COOLANT TEMPERATURE SENSOR. SEE IF COOLANT TEMPERATURE IS BAD THE COOLING FAN OR FANS WONT RUN.
Sep 07, 2009 | 1997 Plymouth Voyager
Overheating 97 V6 pontiac grand am
1 Inspect Cooling System Mix Coolant level low or flow is restricted. grey_line.gif 2 Inspect Belt Incorrectly routed, adjusted, tensioned, missing, or worn water pump belt(s). grey_line.gif 3 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose. grey_line.gif 4 Inspect Radiator Cap Worn or damaged radiator cap grey_line.gif 5 Inspect Thermostat Thermostat stuck closed grey_line.gif 6 Inspect Fan Blade Broken, missing, or defective fan blade(s). grey_line.gif 8 Inspect Water Pump Damaged, worn or leaking water pump. grey_line.gif 9 Inspect Intake Manifold Plenum - Perform Leaking water pump gasket. grey_line.gif 10 Inspect Cooling Fan Control Faulty cooling fan control or circuit. grey_line.gif 11 Inspect Cooling Fan Switch - Radiator Faulty radiator cooling fan switch or circuit. grey_line.gif 12 Inspect Engine Temperature Sensor Faulty engine temperature sensor or circuit. grey_line.gif 13 Inspect Temperature Switch Damaged or faulty temperature switch or temperature switch circuit. grey_line.gif 14 Inspect Fan Clutch Worn, loose or faulty fan clutch. grey_line.gif 15 Inspect Ported Vacuum Switch Damaged, leaking, or faulty ported vacuum switch. grey_line.gif 16 Inspect Radiator Obstructed radiator core or radiator cooling fins. grey_line.gif 17 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders
Dec 01, 2008 | 1997 Pontiac Grand Am
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
