Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Weed eater wouldsnot work , took it apart found fuel lines broke. I then replace them with new one,s don,t know if they are on right
  • 1,835 Answers
Posted on Apr 10, 2016
  • 246 Answers
SOURCE: weed eater featherlite primer bulb won't fill with
Hello
From your Description and Depending on the OEM (Zama or Walbro) of the Carburetor it Sounds like a Bad Fuel Filter or the Primer Check Valve has Stuck and the Carburetor Requires Soaking and Cleaning.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.poulanpro.com/poulanpro/indexAction.do?id=default and Select Order Parts and Accessories. On this Page Select Illustrated Parts List from the Menu on the Left. Now Select the Manufacturer (Poulan/Weed Eater) and Enter the Model Numbers in the Boxes at the Lower Left of the Page.
I Require the OEM (Walbro, Zama, ect) and the Model Numbers Off the Carburetor. With these I can Locate a Breakdown of the Carburetor and Better Assist you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
#1 Taper
  • 1040 Answers
SOURCE: lose gas line poulan weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines.
(HINT): when feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Jim
Posted on Jun 14, 2009
#1 Taper
  • 1040 Answers
SOURCE: Fetherlight xt200 fuel line connections
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • 634 Answers
SOURCE: Can,t prime fuel with primer ball on my weed eater
sounds like it has gotten dirt in it, flush lines and tank with brake cleaner, remove primer bulb usually 4 screws and clean under there too reassemble and try again fixes most of the time
Posted on Jul 08, 2009
  • 3600 Answers
SOURCE: WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Posted on Aug 13, 2009
Why weed eater wont stay started
  • #1 - Change Fuel Filter
  • #2 - change or clean Spark Arrestor
  • #3 - Change or clean Spark Plug
  • #4 - Clean carburetor
Order of importance, Start at #1 and work forward.
Look here...
Jul 22, 2014 | Echo Garden
How to change the fule line of weed eater?
There should be clamps on either end of the fuel line..1.. empty the fuel out of the weed wacker ..2..loosen the clamps..3..remove the hose ..make sure you are careful when replacing any fuel lines..so you dont puncture a brand new one..tighten the clamps good but not too hard or you can pucturethe hose that way too and make sure its the right one for that model. make sure the line is also fuel resistant..gasoline can eat through the wrong type of line. You should be able to buy the fuel line and clamps at any hardware store:)remember to ask for help from someone in the right department
Apr 14, 2014 | Garden
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
My weed eater's fuel lines are busted, do i need to get the whole tank assembly, it looks like their is a filter or float or some sort on the end of the line insisde the tank?
No, you don't need a new tank. You are right about the filter inside the tank.It will make it very easy for you if you can buy the new lines with a new filter attached, but if not, just buy the fuel line.
Jul 06, 2011 | Craftsman 25cc Gas Line Trimmer
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Lose gas line poulan weed eater
Jim
Jun 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
73 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
