Question about HP Deskjet 3845 InkJet Printer
Not printing, says out of paper
My printer says it is out of paper which it is not. I have tried moving the paper around but for some reason it is not reaading that there is paper in the paper drawer. The printer is less than a year old. Thanks.
Linda
    Problem Solver:
  • 6 Answers
Check to see if there is any Resume print button on your printer, if there is not one. REinstalling the Printer will most likely fix this problem
Posted on Apr 23, 2009
Printer part not moving paper
Assuming that you actually mean almost the opposite, "Printer not printing or moving paper" what is it doing, please?
Neither printing at all nor moving the paper prolly means the printer isn't getting data...
Printing mixed up stuff in the same space without moving the paper means the data is garbled but gives no clue to whether the garbling is due to the printer or to the computer.
Assuming you have only one printer, does it behave exactly the same way with all documents? Does it make any difference what application made the document? Does it make any difference whether you try to print a new document or one that's previously been Saved then Closed and edited?
What happens if you try the printer's self-test routine?
After all that, one common reason for printers failing to move the paper is that rollers have become shiny with age. If that's the problem and you can reach the right roller, it might help to rough it up with something like a nail file or the striking surface from a box of matches - not safety matches; the Swan Vestas type.
Aug 21, 2016 | PRINTER Office Equipment & Supplies
When I print a page, the paper appears to have been twisted and the print is off the page on bottom left
There can be many reasons for this problem. All of them are connected with paper transport. What model is your printer? Try to find some small pieces of paper inside the printer. Something stops the paper to move correctly!
Sep 23, 2014 | Konica Minolta Konica Bizhub C353 Drum...
My Ricoh Aficio SP-C210SF Printer jams almost every other print i make. What should I do?
is the machine new?
check the paper size, check the paper tray -if the paper end fence is loose(the paper should not move around).
try using fresh paper(from a sealed pack)
Jan 07, 2010 | Ricoh Aficio SP-C210SF Printer
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Jan 02, 2009 | Samsung ML 1510 Laser Printer
Printer Won't Take Paper
I beleive that machine has two slots to put paper, try moving the tray to the other slot, for some reason it may have defaulted to that tray.
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
Problems with Dell All-in-One 924 InkJet Printer
Try cleaning the rubber roller on the paper pick up with a damp cloth, or rubber roller cleaner.
Nov 17, 2006 | Dell 924 All-in-One InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
