Question about Sub-Zero 661/F Side by Side Refrigerator
Leaking water dispenser - Sub-Zero 661/F Side by Side Refrigerator
    Scholar:
  • 50 Answers
Bernie,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispensor is ALL the way closed.
Posted on Oct 12, 2013
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Kenmore 253.52632200 refrigerator water dispenser leak. The water dispenser in front of the door leak water slowly. Sometime it leak a lot and sometime it does not leak
You need to replace the water dispensing solenoid valve located in the back of the fridge and your problem will be solved.
Dec 12, 2010 | Kenmore Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
The water dispenser leaks
The most likely reason for the leaking at the water dispenser is the dual water control valve on the back and near floor is leaking water while shut off. The only option is to replace the water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
The Water dispenser is leaking water
It's either a bad water valve or the switch in the dispenser is stuck.
Oct 19, 2007 | KitchenAid KSRG22FK Side by Side...
Sub-Zero 661/F Side by Side Refrigerator Logo
115 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
