Question about Dell E771MM 17" CRT Monitor
Resolution native humma
Why i cant open the humma page??
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: How can i set 1440x900 resolution on X600 mobility radeon?
Try installing the latest video driver then you most likely can set it to a higher resolution.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Sep 08, 2012
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
Can you restore my laptop screen to full size at the moment it is half size
Open up a web page on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size % click a different percentage
also a text size you might try a different text size although this will not increase the size of the page only the text inside it
if you do not see these tabs in the top toolbar right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
right click in the top toolbar select the menu bar this will add the menu to the toolbar then select the view option then from the drop down list select full screen
alternativevly
Change the resolution of the screen to its maximum in cases where the screen size has been compromised due to selecting a non-native resolution.
To accomplish this, right click on the desktop and select the option to "Personalize."
From there, click on "Display Settings," then slide the resolution bar all the way to the right and press "Ok" to confirm your choice.
This should restore your screen to its proper size.
hope this helps
Sep 17, 2012 | Dell Latitude D 630 D 640 D 520...
Sep 07, 2012 | Dell Latitude D810 PC Notebook
Need to get screen size to show all . cant see
Things to check: Are your display settings set to "native resolution" of your screen. The native resolution is the actual dimensions (in pixels) of your flat-panel screen.
Looks like the Dell E153FP 15" has a native resolution of 1024x768. In windows, go to your control panel, in display settings, and ensure the resolution is set to 1024x768.
If that does not work, you can try the "auto adjust" feature on the monitor. On many Dell monitors, you can get this by pressing and holding the + button (on the monitor). You'll see the words "auto-adjust" appear on the screen if this works. If that doesn't work, you may be able to find auto adjust by navigating the menues in your monitor's menu, which you can get to by pressing the "menu" button on your monitor (sometimes this looks like a little rectangle icon). If it's an alignment problem, this should fix it right away.
If neither of the above work, it's probably your video card. Make sure your video card drivers are the correct ones for your card and OS, and up to date. You can also mess with display options under Control Panel > Display, under the "settings" tab, and at the bottom click the "Advanced" button, and it will bring up the advanced settings for your videocard.
Apr 23, 2010 | Dell E153FP 15" LCD Monitor
ViewSonic Optiquest Q7b 17" LCD Monitor has a fuzzy picture
LCD monitor needs to be fed with native resolution from the PC video out, this monitor native resolution is 1280x1024 @60Hz, try that setting to see if it helps before opening up the monitor to look for failed components.
Mar 29, 2010 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Cant see the screen to change my native resolution and cant get my PS3 to show any picture on my tv. Just changed ps3 from one tv to another and it wont display.TV techs say change native resolution to...
These newer game console (PS3 in particular) don't like to be changed from one TV\Monitor to another. I changed mine several times before I had problems with it. I guess, it was once I hooked it up to an HD TV\Monitor that it didn't want to display on a Non-HD TV\Monitor. The way I fixed it was by resetting\restoring it to original settings. WARNING: This will most likely wipe-out all saved games, demos, & etc. Restoring your PS3 to original settings. This is how it's done: Turn off PS3, Unplug PS3, Wait a couple minutes and re-insert plug, Push & hold-down power button until you hear 4 beeps (1,1,2) then let off the power. It should show you a page with restoring options, or a prompt of YES or NO of wanting to enter the Restore Options Page. Choose the one that you would like to do. See MADHATTER COMPUTERS. You can also find us on Facebook.
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
I cant get the monitors resolutin at 1440x900-60Hz and the monitor keeps going to sleep
your graphics card doesnt support the resolution that your monitors native resolution is set at.
btw, what graphics card are you using?
Nov 23, 2007 | HP Compaq WF1907 Monitor
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Dell E771MM 17" CRT Monitor Logo
13 people viewed this question
Alun Cox
