Question about LG Dryer Main Control Board - EBR36858801
Dryer will not do anything. Has power at outlet.
    Scholar:
  • 50 Answers
Clif,
Almost all dryers have thermal protection in redundancy to prevent fires. This includes a thermostat, thermal fuse, and high limit switches, normally in the back of the dryer. Gas or electric. If any of these fail you wont run. But, if it is an electric dryer, you MUST have 220VAC at the outlet. 110VAC to ground on each leg dont cut it. if your qualified, measure between the two legs for 220.
Posted on Oct 12, 2013
Dryer began cycle for a second then stopped, screen dark, wall power on
http://www.repairclinic.com/PartDetail/b200p8/LG-Dryer-Main-Control-Board/EBR36858801/1369218?modelNumber=DLE2050W&ss=a8b200d865040&mr=1
Nov 23, 2015 | LG DLE2050W 7.1 cu. ft. Front Load...
The control panel will not work, no lights on panel.
First make sure you house fuse or breaker didn't trip. If you have power to the dryer house outlet, next check the connections where the big 220 volt power cord goes into the dryer. Should be a small access cover you can take off to look at the power cord connections. Sometimes when they are first installed they are not put on tight. Over time they over heat and burn at the connectors. If either side is burned that may be your problem. If all connectors are good, you could have 2 possible circuit boards bad. 1 would be the display board itself (the one with the touch screen) or the main PCB board under the control panel in a tan looking cover box.
Mar 01, 2015 | GE Profile Harmony DPGT750EC Electric...
Blocked in PAUSE
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control board.
Oct 23, 2013 | Washing Machines
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
My samsung steam washer is displaying nothing. I have replaced main controlboard and display board and still nothing. Iwhat does the trans -reactorv do , ould this prevent the display from working. I
se this causes, and fix it. otherwise you must call some tech professional. God bless you
Check Power
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Sep 22, 2012 | Samsung DC26-00009F - TRANS-REACTORV
Wired outlet incorrectly and breaker tripped. dryer will not come on. there is power in the outlet. no beeps or anything, completely dead. model number gleq2152es
hello if it striped the breaker theres a dead short somewhere in the dryer something on the power supply board could have shorted to ground check the glass fuse on the power board of the dryer if blown make sure you use the same rated fuse also check the capaitor next to the motor these can go short circuit hope it helps
regards
shaun
Jan 04, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Nothing powers up. no lights come on. it won't do anything
no lights no power means your control board is gone or your machine isnt getting power fromt eh outlet make sure you have power going to the machine
May 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
MY LG DLE5977 Electric Dryer will not power on
Check the junction connection behind the dryer where the power cord and terminal block to make sure that the screws are tight.  Then use a volt meter to check for voltage.  The 2 outside wires should be hot leads and the center is neutral.  Check hot to hot and you should get 240 volts.  Check hot to neutral and you should get 120 volts.  If you get those voltage readings, then you have a control board malfunction and needs to be replaced.  There is no reset switch within the dryer for the control board.
Jun 09, 2008 | LG DLE5977 Electric Dryer
No nothing! -Kenmore HE3 DRYER # 82826
Unfortunately, the Main Control Board generally is the culprit that kills the entire dryer on these models. The tech sheet you discovered should also give you the test points to check the control panel too. However, if the Main Control Board is bad, it will do you no good to try to trace voltage if it's not there. In addition, the connector pins are so small it makes it rather difficult to even try to get good resistance readings. Now...to rule out other possibilities: THERMAL FUSE - Would kill all dryer functions, but I believe the control panel would still work and the interior drum light would come on. THERMAL CUT-OUT - Would only kill the HEATING portion of the dryer. The drum would still rotate, but the unit would not heat. DOOR SWITCH - Control panel would still function, but dryer would not start and drum would not rotate. BELT SWITCH - This will shut down a dryer if yours is equipped with one. I don't believe this model has such a switch, but even if it did, the dryer would not start, but the control panel would still light up. So...other than double checking all your wiring to make sure you don't have anything broken or loose, you have probably narrowed it down to the most likely cause. You still might have a defective interface panel, but they don't fail as often and are more expensive. Generally, the whole panel has to be replaced. I hope this guides you in the right direction. If you need further assistance, post comments.
Aug 17, 2007 | Kenmore 82822 Electric Dryer
Dryer will not start
slats Does display shows anything? Does any indicator light on the control panel lights up? When you open the door did you see the light comes on? If nothing happens, there is a problem with the power source from the outlet or the power cord not connected properly (possible burned out wires) to the dryer. If you see the light inside the dryer, then the problem is a bad control board. Let me know and do not place a new question. Just put a comment and I'll get e-mail notification. Gendos...post back
Mar 03, 2007 | Whirlpool GEW9868K Electric Dryer
LG Dryer Main Control Board - EBR36858801 Logo
120 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
