Asus p5ld2 does not detect hdd, sata or idle,don't show up in bios, mb is new just hooked up. cd/dvd on idle master works fine.
    Problem Solver:
  • 5 Answers
Buy new hard disk . or enable it to bios .
Posted on Oct 20, 2013
4 Suggested Answers
  • 10 Answers
SOURCE: SATA II HDD instaling on ASUS P5LD2
Drivers will not affect whether the drive shows up in BIOS or not.
Your BIOS should have a setting under the 'Advanced' section for IDE and or SATA. Usually this needs to be set to 'Enhanced' mode or 'SATA plus PATA'  Check your jumper settings-The drive should be set to 'Master' (if it even has jumpers).Check the power lead to make sure the drive spins up. Try different power lead and different SATA cable. If possible, try the drive in another machine to make sure it isn't 'Bad out of the Box'
If the drive does not show up in BIOS its a hardware issue or BIOS setting .
Once it shows up in BIOS - you'll be good to go.
Posted on Oct 31, 2007
sodeep
  • 3267 Answers
SOURCE: Asus P5VD2-VM SE don't detect sata hdd
What processor are u using & which OS have u installed? Try using WinXP_ServicePack-3.........sodeep
Posted on Mar 20, 2009
  • 67 Answers
SOURCE: Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Posted on Jan 23, 2010
New asus mb doesn't detect hdd, sata or idle thay don't show in bios, set bios correctly still no go. cd/dvd detected and works fine on idle master
You checked with the another sata cable.
if checked and not working then your mb's sata port are not working.
Oct 12, 2013 | Computers & Internet
Unable to use S-ATA on Asus P5LD2-VM
in the BIOS set the SATA controller to IDE this should fix the problem. And try with AHCI selected.
Apr 16, 2013 | ASUS P5LD2-VM Motherboard
Hi dear Expert. I Have my MB ASUS M2A-VM HDMI. SATA1(0) was connected with HDD Samsung 320Gb. SATA2(1) was connected with CD drive. Other ports spare. Now by commecting new HD Samsung 1Tb on SATA3(2)...
If the new Drive is setup on a different channel than the First HDD and CD then it should be set to Master. In the Bios you probably need to activate the second SATA channel so the Auto Detect Function can work. You also need to check that the MB can support a drive that size. Not all MB will support an HDD of that size. Aside from the Obvious of checking all your cable connection to insure that they are all solid the only other thing I would recommend is that you switch the CD and new HDD positions. Put both HD's on the same SATA channel and the CD on the Separate channel. This would require making 1 HD a Master and the other a Slave and changing the CD to a Master since it will have it's own Channel. Second, try remove all but the New HDD from the system. Set the New HDD up as the only HDD and see if the BIOS will see and allow you to select it. If it will not there is a problem either with the size of the HD or with the HD itself.
Sep 23, 2010 | ASUS M2A-VM (0610839149438) Motherboard
Jan 22, 2010 | ASUS Computers & Internet
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Sata DVD Ausus using K8V-MX
TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
note:
Jan 06, 2008 | ASUS K8V-MX Motherboard
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
