Question about Philips 32PT5441/37 32" TV
There is a band developing
The band is developing across both the top and bottom of the screen. This happened over a year ago, where the tech replacrd some capicatators, and repaired the printed circuit board. Cost was over 200 bucks then--The TV 2 yrs , 9 mo old. Should we junk it-- or is there any better way to handle it ? Thanks
    An expert who has answered 500 questions.
  • 556 Answers
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Posted on Sep 25, 2007
Screen blinked and then there was a dark band across the top of the screen
This sounds like one of the back lights have failed. This could be its power supply, and or the lamp itself.
Not all the screens can be service for back light failure. This is design dependent. Also, if you are going to change a back light and you can, it is best to replace all of them at the same time. If not the coloration of the screen will be different from one part to the other. With age the color of these lamps changes a little.
I would suggest with such an old set, I would get one of the newer LED/LCD sets. They are very far improved over the one that you have. Your set will be expensive to service, if it can be serviced.
Jerry G.
Jul 27, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical Band has appeared on my TH-42PX60B
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Feb 20, 2012 | Panasonic VIERA Televison & Video
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
I have a narrow green band across the top of the screen similar to a rainbow -also Ex: most of what appears on the screen is double vision. thankyou.karen t.v. is approximately 8 years old
Your TV needs the convergence ICs replaced .
Not something you can do, techs usually charge about $300-$400 to replace them in your house.
I may be worth fixing if you can find a reliable tech in your area.
best of luck
Dec 17, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
Horizontal lines across the top 3 inches of picture
what line started? from Left to right? or from top to bottom?
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Philips 32PT5441/37 32" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
