Question about Canon Pixma MX410 All-In-One Printer
Scan slide negatives film
How can I scan a film negative using a Canon MX410? Thank you.
    New Friend:
    Problem Solver:
  • 9 Answers
I have had that problem with the MX310.
depending on what IOS you are running
you can get software free that will scan
Transparencies "opposite"
Posted on Oct 12, 2013
SOURCE: negatives to pictures
The manual didn't show negative and slide support. I recommend you some of the hp products like HP Photosmart C7180 All-in-One, HP Scanjet G3010, HP Scanjet G4010, etc.
Posted on Feb 09, 2008
SOURCE: scanned 35mm slides show as
Reread instuctions. What else? Andre confirmed it.
Thanks
Posted on Jul 16, 2008
SOURCE: hello - i have a
Did you look under the white foam protective cover on the underside of the lid, the one that looks like its sole purpose is to press documents flat against the glass? That's where the film guides are stored, believe it or not. See page 65 (of the file, page 63 as numbered on the pages themselves) of the manual here:
http://www.instructionsmanuals.com/u2/pdf/multifuncion/Canon-PIXMA_MP800-en.pdf
Posted on Sep 19, 2008
  • 69 Answers
SOURCE: Can I purchase a new
You probably can get it from Canon.
Give them a ring.
Posted on Oct 08, 2008
  • 2678 Answers
SOURCE: How can an ordinary canon pixma mp258 printer and
It can't you need a scanner that will scan negatives and slides.
Posted on May 05, 2010
How to scan negatives?
You will need to check your Canon software that came with your Pixma MX310. I have a stand alone Canon Canoscan 8800F scanner that have the capability to scan 35mm film strip and 35mm mounted slide, the software included the feature for it.
Nov 07, 2013 | Canon PIXMA MX310 All-In-One Printer
Can it scan film negatives?
You cannot scan negatives or slides with this all in one printer.
You need a film scanner.
May 07, 2013 | Canon PIXMA MX882 Wireless All-in-One...
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
I am tring to scan my 35mm negatives
Select scan. When the window pops up look in the upper right hand corner of the window. You will see select source: drop down menu give you choices which includes negative film. Just select it. Then drop negatives into holder. Oh, make sure you remove the cover sheet that slides in and out of the cover.
Mar 19, 2009 | Canon CanoScan 5000F Flatbed Scanner
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
My scanner doesn't scan negative
" I can only select platen as the sourc. the film setting has vanished" - I had the same problem. Unplugged the USB cable from a shared usb 2.0 hub and plugged into an old USB 1.1 dedicated port and it started working. No ideas why (perhaps in the hub it couldn't detect the scanner model correctly)
Aug 12, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
Canon Pixma MX410 All-In-One Printer Logo
304 people viewed this question
old marine
old marine
