New asus mb doesn't detect hdd, sata or idle thay don't show in bios, set bios correctly still no go. cd/dvd detected and works fine on idle master
    Sergeant:
  • 252 Answers
You checked with the another sata cable.
if checked and not working then your mb's sata port are not working.
Posted on Oct 12, 2013
  • 3 more comments
  • Ralph  Howell
    Ralph Howell Oct 12, 2013
    here is "food for thought" switched up, put a sata dvd/cd in connected to sata #1it was detected an works fine. Ichanged the connector
  • Sandeep Kumar Oct 12, 2013
    You have four/Two SATA Port on the motherboard.
  • Ralph  Howell
    cable to hdd ribbon idle, no go on that idle master tryed 2 other hdd's still no go.
    then hdd have some issue.
  • Ralph  Howell
    Ralph Howell Oct 16, 2013
    solved detectshdd's an runs fine
mumma_1
  • 903 Answers
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Posted on Nov 17, 2008
SOURCE: Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
Rate me if this helped.
Posted on May 29, 2008
siawolf
  • 749 Answers
SOURCE: pin settings on a samsung hd080hj/p sata hdd
Hope this helps.
Posted on Apr 11, 2009
sodeep
  • 3267 Answers
SOURCE: cannot reinstall new os, seem my hard drive is not detected by os
I hope its not Vista os, because if the driver is not in its database, it does not accept any new driver. Install XP first and run the Vista Upgrade adviser from microsoft to check whether your PC hardware will run Vista....sodeep
Posted on May 16, 2009
rockitman187
  • 2559 Answers
SOURCE: Dimension 4600 bios dosen't see SATA HDD
Just reload the SATA drivers,you can use an xp disk and select F6 when ask if you want to install 3rd party driver,Just have the driver disk ready when it ask for it and use the second repair option instead of the first to prevent a total reinstall.
Posted on Jun 04, 2009
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Hi dear Expert. I Have my MB ASUS M2A-VM HDMI. SATA1(0) was connected with HDD Samsung 320Gb. SATA2(1) was connected with CD drive. Other ports spare. Now by commecting new HD Samsung 1Tb on SATA3(2)...
If the new Drive is setup on a different channel than the First HDD and CD then it should be set to Master. In the Bios you probably need to activate the second SATA channel so the Auto Detect Function can work. You also need to check that the MB can support a drive that size. Not all MB will support an HDD of that size. Aside from the Obvious of checking all your cable connection to insure that they are all solid the only other thing I would recommend is that you switch the CD and new HDD positions. Put both HD's on the same SATA channel and the CD on the Separate channel. This would require making 1 HD a Master and the other a Slave and changing the CD to a Master since it will have it's own Channel. Second, try remove all but the New HDD from the system. Set the New HDD up as the only HDD and see if the BIOS will see and allow you to select it. If it will not there is a problem either with the size of the HD or with the HD itself.
Sep 23, 2010 | ASUS M2A-VM (0610839149438) Motherboard
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me chepu_456@yahoo.co.in
Feb 21, 2008 | ASUS K8V-MX Motherboard
Sata DVD Ausus using K8V-MX
TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
note:
Jan 06, 2008 | ASUS K8V-MX Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
