Question about Sanyo Office Equipment & Supplies
PLV-60HT: When I turn the projector on the fans come on briefly but as soon as the lamp gets power the unit shuts down, everything goes off including the LED status lights on the top panel. Projector has to be unplugged for 15 seconds (or so) and then plugged back in to get the LED status lights back on. I have replaced the bulb and tried the recessed "reset" button... what else is there to try?
    Top Expert:
  • Sanyo Master
  • 24,373 Answers
Could be a fan sensor or a faulty power supply.
Posted on Aug 07, 2017
SOURCE: No Light from projector (worked previously)
theres prob something wrong wif the bulb
Posted on Dec 20, 2007
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
Basti
  • 1447 Answers
SOURCE: projector shut down
Hi
Replace the lamp, or better yet try removing and reinstalling the lamp.;
Hope this helps
Posted on Nov 01, 2008
projdoc
  • 2237 Answers
SOURCE: rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Posted on Nov 12, 2009
projdoc
  • 2237 Answers
SOURCE: Projector powers down as soon as LAMP lights up
the ballast/power supply needs replacing.
Posted on Dec 23, 2009
Why is my sanyo plv wf20 projector shutting down after I turn it on.
The fan may be out that keeps the bulb cool. The shutdown is to protect the lamp from overheating. Do you have any flashing indicator lights on the projector after turning it on?
-GWOOD
Jul 12, 2014 | Sanyo PLV-WF20 Projector
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLV 60 HT keeps on overheating even after I cleaned the
hi dear plz check the projectors fan. It is working properly or not
Jan 31, 2010 | Sanyo PLV 60HT Multimedia Projector
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
SANYO PLV-70 - powers up for approx 5 secounds and then turns of
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
Dec 11, 2008 | Sanyo PLV 70 Multimedia Projector
65 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
