Question about LG Dryers
Lg clothescare dryer dlec733w
Light keeps coming on to "Empty Water" and stops the dryer and the water tank is empty. Repair guy told us we needed a pump so we ordered one and now have no idea how to replace it. This is number for the part we ordered: aha33538702 Help!
    Master:
  • 818 Answers
Alrighty then lets get crackin- You have the new part to look at open up the machine-usually a bunch of screws on the back. Look for the similar part-here comes the fun-remove it carefully-take note of plugs ,wires, hoses, mounting position. reassemble close it all back up plug it in and let her rip-hopefully you have just fixed your machine-be sure to check for leaks at all your water connections-they can make a mess of things-cheers Denny
Posted on Oct 12, 2013
SOURCE: I have a Hoover vision hd b energy condensor dryer
My engineer is coming out, didnt realise i had to pay for this assistance,it made out on the ad that someone was able to help you by giving advice,it didnt state you had to pay, for i thought forget it.
Posted on Aug 27, 2009
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
SOURCE: Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Posted on Jun 29, 2010
SOURCE: zanussi tc7103w condenser dryer-water tank
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Posted on Jan 19, 2011
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
There is usually a sensor beyond the fluff filter that cuts in if over heating which can clog up with finer particles of fluff that evade the filter and give the impression of overheating, that is what is likely to be the reason. It is a job that needs a technician as it requires some dis-assembly.
Nov 11, 2013 | Dryers
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
Sep 23, 2010 | Dryers
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
