Question about Printronix T5000r Label Printer
083 decimal INPUT ERROR - Printronix T5000r Label Printer
HP 14B need to set decimal point
Shift (yellow) button and DISP (above close parenthesis).
N button.
Will show FIX _
Input required number of decimal places
That's it!
Feb 13, 2014 | Office Equipment & Supplies
I want to set the decimal place without using the decimal key--example: hit the 1234 keys and the shows $12.34
You can select the A (K . A) and then the # of decimal places (F 6 3 2 1 0) you want. So if you want to enter 1234 & it calculates 12.34, this will work.
Jul 22, 2011 | Sharp EL-2630P Calculator
My calculator keeps giving a particular error. I know that it shouldn't give this error. So eg, I do 0.95/99.05 = 9.59111.5598x10-3. It should be 0.0095. Can you please tell me how to correct this? I...
The error is in the eyes of the beholder. In scientific notation your value of 0.0095 is written as 9.5*10^(-3). Actually the calculator showed you more digits than you were asking for and its answer is more precise that yours. When you choose the Input/Output of the calculator to be LineIO, it will show the results as decimals. Howvever if the number to be displayed is too small or too large, the calculator will use the scientific notation.
To do exact calculations (whenever possible) set the Input/Output mode to MathIO. The result will be a fraction (19/1981). After that you can press the [S-D] button to convert that exact result to its decimal representation.
If you do not mind my advice, I suggest you learn how to interpret scientific notation, and familiarize yourself with the capabilities of this new type of calculators.
To configure the calculator for MathIO, press [SHIFT][MODE] to open the (SetUp), then select [1:MathIO]. In this mode, you will be able to see the expressions you type in as they would appear in a textbook:Fractions will appear as fractions, you will see radicals, etc. You can do a string of calculations in MathIO and convert only the last result to its decimal representation.
Jul 10, 2011 | Casio fx-300ES Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Everytime I input a negative sign in the PV figure in the tvm solver I get syntax error
Use the (-) key to the right of the decimal point key instead of the - key to the right of the 6 key to enter negative values.
Feb 04, 2011 | Texas Instruments TI-84 Plus Calculator
When i input Xmin -10, Xmax10 and Ymin -10, Ymax 10 error 07 syntax keeps reappearing and isnt allowing me to input and save the data
Use the (-) key (just to the right of the decimal point key) instead of the - key to enter negative values.
Jan 29, 2011 | Texas Instruments TI-86 Calculator
I just bought this fx-115es and am entering 5x3.3= and getting an answer of 33/2, althought it is right how do i get it to answer 16.5
There are several ways you can extract decimal numbers from this fine calculator.
In MathIO Mode
1. Once a fraction or radical is displayed press [S<=>D] button to convert it to decimal. Pressing it again restores the fraction or radical display.
2. Instead of pressing the [=] key to obtain a result, press [SHIFT][=]. The result will be displayed as a decimal number.
In LineIO
If you do not care for exact calculations with radicals and fractions, just change the default mode from MathIO to LineIO. To do so
press [SHIFT]{MODE][2:LineIO]. In this input/output mode all results are decimal.
Please be informed that with this mode you will not be able to access the formula templates that allow you to enter fraction as you see them in textbooks (the natural display format). You lose other neat functionalities also.
As a suggestion, if you like the natural display for input keep it as default, and press [SHIFT][=] to display decimal results or [S<=>D] to convert display to decimal format.
Hope it helps.
Nov 16, 2009 | Casio FX-115ES Scientific Calculator
A c prog to convert decimal to hexadecimal number.
Sure, here you go:
int main(void) {
int input;
printf("Enter a decimal number: ");
scanf("%d", &input);
printf ("In hexadecimal, that is: %X\n\n", input);
return 0;
Oct 05, 2008 | Computers & Internet
Printronix T5000r Label Printer Logo
78 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
