Question about Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15
My 2001 ford explorer won't start after I changed the lock cylinder
  • 34 Answers
Did your Explorer require the computer chip key to start it from the factory? If so, you're probably going to have to visit your "friendly, neighborhood Ford dealer", with all the numbers from your new ign..sw. and the new keys, and a $50.00 bill per key, to have them programmed. Actually, I hope I'm wrong, but I'm fearful that I'm not. Good luck, in any case.
Posted on Oct 12, 2013
99 ford explorer changed ignition now wont start
If your vehicle was towed, check the fuel pump intertia switch located near the top of the passenger side kick panel.
if you changed the key, you will be having an antitheft problem.
you could try putting an original key at the lock cylinder while turning the new key, it may allow it to start... if so, new key will require programming, or have the new lock cylinder coded to the old keys.
Jun 19, 2014 | 1999 Ford Explorer
Wire in a Ford PATS Transceiver F8SB-15607-AC Ignition Lock Cylinder and Key FOB Explorer
i've found a few references on how to by pass this but if you follow this link to the ford explorer forum you will get better info and advice from fellow explorer owners/mechanics who know the vehicle from top to bottom
2002 ford PATS transceiver XLT won start
May 21, 2014 | 1999 Ford Explorer
Where is the pressure valve that needs to be removed to change the master cylinder on a 2001 ford explorer sport
No--why are you changing a master cylinder ?
I just take out the piston & clean out the moisture,
then flush the entire system, all 4 corners
After that-- I do my brake work & then bleed all
4 corners
That has worked for me for 50 years, doing brake work
In the 1960's you could get repair kits for the master
Mar 10, 2013 | 2001 Ford Explorer Sport
2001 ford taurus key won't turn ignition
The steering wheel was turned when the key was removed. So when you try to turn on the key, turn the wheel one way and the other way to release the pressure on the key. The key should turn ok.
Hope this helps.
Jul 29, 2012 | 2001 Ford Taurus
My 93 ford explorer sport started to click then slow down and now it won't start up what could be the problem
sounds like the battery is dead. Try recharging the battery or try jump starting from another vehicle using jumper cables.
Apr 30, 2012 | 2001 Ford Explorer Sport
If you take the switch out can you still start the ford explorer with a screw driver?
Yes, you have to rotate lock cylinder to ON, then insert a small pin into a hole on the side of the cylinder to depess a pin that then allows you to pull out the lock cylinder, with a "screwdriver end" on it that fits into the ignition switch.
Jul 12, 2011 | 1998 Ford Explorer
2001 ford sport trac won,t start changed fuel filter stars but now won't start again after about 2 months
Listen to see if fuel pump is kicking on it will make a high pitch nosie then click off after gas line is pressurized.
Aug 04, 2010 | 2001 Ford Explorer Sport Trac
Backdoor wont open without key battery keeps draing
Ford Explorer 1991-1999
Door Lock Cylinder
  1. Open the window.
  2. Remove the trim panel and watershield.
  3. Disconnect the actuating rod from the lock control link clip.
  4. Slide the retainer away from the lock cylinder.
  5. Remove the cylinder from the door.
  6. Use a new gasket when installing to ensure a watertight fit.
  7. Lubricate the cylinder with suitable oil recommended for this application.
Exploded view of the Explorer/Mountaineer rear liftgate trim panel
For more details, you can visit Autozone.com (free register) and find the Repair Guide.
Good luck.
Sep 01, 2009 | 1999 Ford Explorer
Keys and Keyfob do not open 2001 explorer from outside
Spray some WD-40 into the key cylinders and then try working the key. The locks seize up because you keep using the FOBs.
Mar 25, 2009 | 2001 Ford Explorer
Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15 Logo
80 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
mekanik84
 Robert
Robert
Level 1 Expert
xkikbxr
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
