Question about Kitchen Ranges
Heed to replace the fan/light switch on Technika TB10900 rangehood. Have purchased new switch but it has not come with wiring. The old switch which works apart from a break in the plastic molding which means it is not held solid in the frame, is removed be clicking off part of the wiring ( all the wiring appears to be linked together by a click together system) I dont know how to wire the new switch. any ideas
  • 1462 Answers
SOURCE: My downdraft fan does not run.
i assume you mean the oven fan. does the element heat or not. first thing to check that you have the clock set properly because you may have it set to auto withiout realising
Posted on Apr 09, 2007
SolutionGuy
  • 331 Answers
SOURCE: fitting a new control switch for the fan oven (model number 10450G)
Sesspod, 2 things... 1.) Pull the oven out and look on the back of it, there may be an envelope back there containing a technical data sheet which includes a wiring diagram. If not on the back, then possibly under the cook top. It is somewhere on your oven, sometimes the hard part is locating it. If you can find it, look closely and you'll see the wiring color and location is labeled. 2.) If you can't locate the tech data sheet, can you post a good macro picture of the back of your new switch so we can see what you're dealing with.
Posted on Aug 11, 2007
  • 1314 Answers
SOURCE: Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Posted on Feb 18, 2008
SOURCE: Fans are blowing instead of extracting!!!
just wondering what the problem you had was ? as i,ve just fitted a hood and have the exact same problem....
Cheers !
Posted on Mar 01, 2008
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
I am ready to wire up new fan light my wires from switch to attic are black, white, bare ground the light has several color wires not sure what to do
Black... switched (hot)
White = neutral (return) and bare copper is the safety ground
All good (all as it should be)!
That is an ordinary single pole light switch... Some fans work fine in that application... but a big sprig of colored wires is NOT a favorable sign that you have EVERYTHING YOU NEED.
Pretty sure that you are STILL going to include some sort of PROPRIETARY switch interface.
Depending on the make of the fan (switch options capability)...
or
Taking that fan BACK for the SMART SWITCH... interface
or
a REMOTE CONTROL version that works off of a SINGLE light circuit.
It is not at all UNREASONABLE to expect your retailer to KNOW WHAT YOU NEED... to finish your install.
A word of caution... Be sure to read and HEED the part where they tell you to reinforce the mounting to support the additional weight and motion of your fan assembly!
Be safe!
Dec 29, 2015 | Hardware & Accessories
Where can i purchase a complete filter tray for my rangehood made by Parmco
http://www.axial.co.nz/onlineshop/Rangehoods/rh-Parmco
Sep 18, 2014 | Refrigerators
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
I have a 3 wire replacement light switch but the one in the fan only has 2 wires. Can I use the 3 wire switch? If so how does it wire up?
Kind of hard to be 100% sure without seeing the switch, but seems like the old switch was a simple single pole on/off switch while the new one is a multiple pole switch. The old switch had two positions, off and on. The new one most likely is off/on/on, perhaps used to turn on two banks of lights similar to a 3 way switch on a floor lamp; off/dim/bright. Sounds like it could be used provided it fits physically. Wiring would be power in to one wire and switched to one of the output wires. The third wire should be covered properly with a wire nut and tape to keep it from shorting out. However, there will be a position on the switch which will do nothing at all. After having said all this, I would suggest you purchase the correct switch as the replacement.
Aug 28, 2010 | Hampton Bay 44 In. Bistro, Copper Kitchen...
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
