Question about Ryobi Garden
Gas/oil mixture for ryobi weedeater .how much oil for a gallon of gas.model#ry30020a
It is 2.6 fl oz of oil per 1 gal of gasoline.
Posted on Apr 29, 2009
I usually use 40 to 1 mix thats 3.2 oz to 1 gallon of gas,this is to much oil to gas for my chain saw .which i use 50 to 1 which is same oil to 1.25 gallons of gas,hope this helps you out
Posted on May 05, 2010
    Sergeant:
    Champion:
  • 260 Answers
I like to add enough to let it smoke a little. it will tell you on the side of the mix
Posted on Apr 23, 2009
Gas to oil mixture for 1 gallon of gas
most of my 2 cycle machines are 50-1 which amounts to 3 ounces of oil per gallon of gas. If 32-1 than it would be 4 ounces of oil per gallon of gas. Hope this helps.
Nov 26, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
Do you put oil and gas mixture in eaf weedeater lblower
a 50 to 1 mixture works just fine ,, thats 2.5 ounces of oil ( 2 stroke oil) to each gallon of gas
Sep 11, 2011 | Garden
What is the mixture of gas to oil for the Ryobi SS30?
Hi planeta6...
50:1 will be the mixture of gasoline to oil..
One pint of two cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 14, 2011 | Ryobi Garden
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
Have lost instuction manual. Need to know oil/gas mixture for leave blower Model RY09550
Your Ryobi should take a 50:1 mixture. In the USA, that is 2.6 ounces of 2 cycle oil per gallon of gasoline. I strongly recommend to buy 2 cycle mix that has fuel stabilizer in it. It would come in a 3.2 ounce bottle and mix 1 bottle per gallon.
Sep 22, 2010 | Garden
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Gas to oil mixture for Model # RY 28020
Use 2-Cycle Oil For Mixture of 50:1. They come in 2.6 oz bottles and larger. Use 2.6oz (one small bottle) per 1 gallon of 89 unleaded gasoline. I use and this and it runs like a charm. You can get from HomeDepot or other hardware stores.
Jun 18, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Is my Ryobi weedeater RY30020A, a 2 cycle or a 4 cycle?
If it has a dipstick on it then it's a 4 cycle.
Aug 29, 2009 | Ryobi Garden
Garden Logo
4,559 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
