Question about Saws
I need to replace my electric cord on my Craftsman circular saw. I have the replacement cord and have opened the saw. The new cord ends with just a black and white wire. But the old cords black and white wire connect to a white opaque plastic box. It does not connect with screws. The wires just disappear into the white box, which appears to have no way to open it. So how do I connect the new wires? Does this white box open somehow. On the back side of the white box another set of black and blue wires come out.
  • 438 Answers
My best advice is to sever the wires going into the unit at a point where they are in good condition, obtain a soldering device and solder, some heat shrink tubing addtiquit for the size of wire and connect your new power cord to the these ends, make cretin that the common or wight and the hot witch is black be connected respectively
Good luck and best regards Falco Mueller
Posted on Oct 14, 2013
5 Suggested Answers
deme-tri
  • 90 Answers
SOURCE: Replacing a worn out cord on my old black and
YOU HAVE 5 WIRES
2 FROM MOTOR
3 NEW WIRE
1 FROM THE MOTOR AND
1 FROM THE CORD SHOULD BE JOIN TOGETHER.
THE OTHER FROM THE MOTOR SHOULD BE JOIN TO THE SWITCH ALONG WITH THE OTHER WIRE FROM THE POWER CORD
AND THE GREEN WITH YELLOW LINES
IS TO GROUND TO ANY METAL ON THE SAW.
Posted on Aug 04, 2009
  • 12104 Answers
SOURCE: I have an old circular saw that is all metal
the 2 wires black [power/hot] white[ground/neutral] black should connect to one side of switch other side of switch should continue to one side of winding and other side of winding to white
Posted on Oct 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do I replace the
first find out what wire guage it is and then remove the handle half, making note of where the wires go, you might want to take a picture for ease of reassembly and then remove the old one and replace it making sure not to pinch the wiring.
Posted on Aug 04, 2011
SOURCE: Can the cord on a Circular Saw be replaced? By whom?
you can replace it your self . you can cut cord shorter and put on a new plug. @ home depot you can replacement parts
Posted on Nov 13, 2012
Accidentally ripped powercord into half and it is discontinued all over internet.What are my options to fix it myself?
I would find an extension cord of similar diameter. Cut the "female" end off, and open your saw up. Connect the cut end of the new cord to the same colors ...
This should not be difficult.
Oct 15, 2015 | Skilsaw 5150 Circular Saws
How to replace a power cord on a B&D 7340 type 2 circular saw?
It's not difficult. Open the saw up, and the power cord is pretty much right there. Get a new power cord from B&D, that will be easiest.
Jun 08, 2015 | Saws
No power to circular saw
Remove the part of the handle over the switch and have a multi meter handy. Plug the cord in and test for voltage where the cord goes into the switch. No power, replace the cord; power, go on. Have someone hold the swtich on and test for voltage coming out of the switch. No power, replace the swtich; no power, go on. Check the condition of the brushes and brush springs. They have to be in good contact with the armature to work properly. If the brushes are OK, you may have a problem with the armature or field. These are usually checked at a service center with equipment most people don't have. If you got this far and haven't found the problem, it may be better to get a new saw.
Aug 13, 2012 | Craftsman 13 Amp 714" Circular Saw
Nov 15, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Need a power cord for 71/4 circular saw
I know Sears used to carry replacement cords that fit most of their electric tools. It has been a few years since I got one , but I'm sure they still carry them. If not they should be able to refer tou to some place that does.
May 30, 2011 | Craftsman Saws
Need to replace power cord
there should be screws on the housing to open up to the cord connections...and there are screw type connectors to disconnect the old cord and connect the new cord
May 17, 2010 | Skil 538501 120Volt 714Inch Circular Saw
I need to replace cut electric chord on saw 6390-20
I would go to Milwaukeetool.com and download a breakdown for this tool. But all you have to do is remove the screws holding the handle assembly to expose the switch area and cord. I think they are a T-20 Torx, after removing the half make a note of the wiring before removing the old cord. trim the leads using the old cord as a guide and reinstall. what you want to do is when you reinstall the screws back them until you feel the first thread so you don't rethread it. These are thread forming screws and after a time they will strip out the threads. It is really quite simple
Mar 27, 2010 | Milwaukee Tools Circular Saw 6390 - 20
I have a craftsman model 315 circular saw i have to change power cord where do i put ground wire since it is a 2 prong cord? i have 14-2 gw to replace it with.
If the cord needs replacing because of a defect return it to Sears. Craftman tools are gauranteed virtually forever. I return a circular saw a few years ago agter useing it fo over 5 years and they replaced it, no questions asked.
Jan 30, 2010 | Electrical Supplies
Saws Logo
60 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
